Old 08-08-2005, 02:41 PM   #1
motocrosschump
Will a low battery keep my truck from firing?
at the Dizzy, the hot reads 12.6 volts, when I start turning it over it drops to 9.6 volts. Will that keep the truck from firing?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 08-08-2005, 03:20 PM   #2
rodnok1
rodnok1's Avatar
I believe my mallory runs around 9.6 volts after going through ballast resistor. HEI should fire down to around 5 volts, points I'm not sure of, but it should fire at 9.6
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-08-2005, 09:29 PM   #3
masterbeavis
Having issues
masterbeavis's Avatar
should fire. Ive tested cranking voltage on mine with a fully charged battery, it drops similar to yours, and starts.
Is your truck not starting now? If not, were there any modifications made to it recently? Have you checked your timimg to make shure it is correct? DO YOU HAVE GAS?? In the carberator?? There is tons of reasons for a no start condition.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
