08-08-2005, 07:25 PM | #1 |
headers bolts, Split-lock or...
http://www.ecklers.com/dept.asp?Page...VG5X82TCQL9HNE
Have any of you used these or this type header bolt? They are not giving them away but they look like an solution to future 'head to flange' leaks. In the past I used 12 point bolts (Big Block Intake Bolts) with shoulder lock washers that provided excellent service.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
08-08-2005, 07:57 PM | #2 |
Try "stage 8" Locking Header Bolts. I Started Using These About 10 Years Ago & Wouldn't Consider Using Headers Without These. They Are About $35 A Set From Summit, & Worth Every Penny. & They Are Stainless. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 08-08-2005 at 08:37 PM. |
08-08-2005, 08:20 PM | #3 |
I have to agree with John here. Also through in a set of copper gaskets. These two together are the best thing since sliced bread!
08-09-2005, 02:21 PM | #4 | |
I have this set up on my vette with headers and it has not leaked in over a year with about 2000 miles of driving. I use the dead soft aluminum header gaskets.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
08-09-2005, 02:44 AM | #5 |
I guess I'm cheap. Just cut the flanges and you won't have bolts coming loose. I use stainless header bolts and you can't tighten them very much at all. They stay tight. I don't even check them anymore. I also use manifold gaskets. (7 bucks).
BTW here's a pic of the aftermath of cut flanges. Last edited by Mudder; 08-09-2005 at 02:47 AM. |
08-09-2005, 03:06 AM | #6 |
I also am sold on Stage8 fasteners. The little fingers lock on the bolt heads and serve to hit the header pipe if the bolt starts to loosen. So, not only do they stop bolts from loosening, but if you see one of the fingers/side extentions touching a pipe, then you know the bolt loosened some and needs retorkin'.
Of course, I use them on manifolds to the same effect. No headers here.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
08-09-2005, 01:38 PM | #7 |
Anybody use the ones that have the set screw going down the center of the bolt..after tightening the header bolt to the desired torque...the center set screw spreads the end of the threads out to "prevent" it from loosing. I think these go for around $50 bucks for a set. Would like to hear some experience if anybody can comment. Thx
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
08-09-2005, 01:47 PM | #8 |
the link on the first post will take you there. they look very clean and must do the job but the Stage 8 has a good following and reputation amongst the Board members.
