06-27-2002, 09:42 PM | #1 |
cutting torch
ok Its been a while since I used a torch and I borrowed one today. I know how to use the torch, the problem is I'm not sure what the psi setting on the tanks is suppose to be. Does anyone know?
thanks
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick" ~72 chev swb w/68 front clip "GM Millenium corvette yellow" I use and accept Paypal |
06-27-2002, 11:13 PM | #2 |
Collector of rusty Items
Redneck torch rules
Set the acetylene at 5 to 10 depending on thickness you are cutting. Set oxygen 25 to 100 depending on thickness. 1 inch steel, use 100. 3/4 steel 75 psi. 1/2 steel 50. less than 1/4 use 25
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
06-28-2002, 12:05 AM | #3 |
thanks scrub. I'm just cutting off bolts, so I set the propane @ 5psi and the oxygen @ 50psi and it went smooth.
thanks
