Old 08-14-2005, 08:40 PM   #1
Musclerodz
Extra parts from my '69 K5 4 Sale (UPDATED 8/23)
I am selling off the extras as I find I don't need them anymore from my restoration. I am sure I will have more to sell as I progress.
1. 350 motor with 2 barrel carb mated to TH350 tranny. Does NOT include transfer case. Both less than 20K since rebuild but sitting since '98, $300
2. Power steering pump put on right before Blazer was parked, cap fits loose, I think it needs a gasket, $35
3. Engine fan and clutch, (SOLD)
4. Radiator fan shroud 4WD, $15
5. New points distributer aftermarket OE replacement, (SOLD)
6. RH fender minor damage in front, fixable, no rust in the bottom, $25
7. Air cleaner OE, $15
8. Holley 4252-1 square bore 4 barrel, looks decent, been sitting awhile, $65
9. Early iron manifold to fit Holley above, front oil fill, (SOLD)
10 Front buckets, non original covers, drivers side torn, $250
11. Under dash heater assy with controls, $100
12. NOS heater only controls in the box, (SOLD)
13. NOS K5 side trim black, 8 of 10 pcs. missing same piece on both sides between door and rear wheel opening, still in original packaging, $250
14. Used slightly dented Blazer fuel tank with sender, $65 shipped
15. New steel fuel tank kit complete still in the box shipped to me, (SOLD)
16. '69-72 hood good shape $75
17. Gauge cluster with aftermarket tach, extra speedo and fuel guage, $25
18. Light bar with 4 lights, 2 are KC, $35
19. Steering box freshly rebuilt before truck was parked, $75
20. NOS 15x6 ralley spare, $40 (pic in post #50)
As I find more stuff I will update it here. I take Paypal or MO or cash. I prefer not to ship the bigger stuff but will if need be. I am South of OKC, OK 30 min. if someone would like to pick anything up. Here is a few things I am willing to trade for:
1. Perfect or near Blazer or truck doors.
2. Perfect or near '67-'68 hood
3. Good 12 bolt POSI unit for 3.73+ gears
4. New hood hinges
5. Good '73 or later steering box to use with lift kit.
6. Good RH inner fender
You can PM, email or post here for inqiures.
Mike
Musclerodz is offline   Reply With Quote
Old 08-14-2005, 09:21 PM   #2
rage'nrat638
rage'nrat638's Avatar
intake
9. Early iron manifold to fit Holley above, front oil fill, $35
i will take this.....can paypal
ship to
mark ramirez
2400 nan st
aurora il 60504
rage'nrat638 is offline   Reply With Quote
Old 08-14-2005, 10:00 PM   #3
Musclerodz
ship to
mark ramirez
2400 nan st
aurora il 60504
PM sent twice, did not see your zip first time.
Mike
Old 08-14-2005, 11:09 PM   #4
rage'nrat638
Cast Squrebore Intake
Intake sold
Need Addy To Send Mo....
Or E-mail To Paypal
Old 08-14-2005, 11:16 PM   #5
Musclerodz
Intake sold
Or E-mail To Paypal
pm replied
Mike
Old 08-14-2005, 11:22 PM   #6
rage'nrat638
you got cash my friend.....thanks mark....the rage
Old 08-14-2005, 09:24 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by Musclerodz
2. Power steering pump put on right before Blazer was parked, cap fits loose, I think it needs a gasket, $45
Does this include the Brackets
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-14-2005, 09:53 PM   #8
Musclerodz
Nope. Brackets were Z/28 Camaro. They are on ebay now.
Mike
Old 08-16-2005, 11:54 PM   #9
zeusflash
zeusflash's Avatar
What is the condition of the engine fan and clutch?(clutch tight/damaged blades) Same question on the OE aircleaner.(corrosion/dents) How much to ship to 83854?
Thanks,
Mike
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 08-17-2005, 12:11 PM   #10
Musclerodz
Thanks,
Mike
Clutch has resistance, but don't have a new one to check it against. No damage to the blades. Air cleaner has couple of small surface rust spots easily removed and no dents. Shipping around $15
Mike
Old 08-17-2005, 12:58 PM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Doors
The doors that you listed, do you have a original passenger side blazer door that is in good shape?
D.PASSMORE is offline   Reply With Quote
Old 08-17-2005, 06:10 PM   #12
Musclerodz
I have an original door but needs work. Has a speaker hole in it as well.
Mike
Old 08-17-2005, 01:41 AM   #13
Larry68GMC
Can you get the numbers from the block and heads on the engine? 2 or 4 bolt? Thanks...
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 08-17-2005, 06:08 PM   #14
Musclerodz
Block casting is a 3970010. Head # all I have found is an 063. I have not checked the vin yet but if it is the original block which I "don't" think it is, but if it is I will be keeping it. I am just South of Norman if you want to come look.
Mike
Old 08-17-2005, 06:26 PM   #15
zachary2001
What Is You Low Dollar On The Motor I Don't Really Need The Transmission I Just Had My Rebuilt Always A Day Late Or A Dollar Short ...
zachary2001 is offline   Reply With Quote
Old 08-17-2005, 06:55 PM   #16
Musclerodz
I would take $200 for the motor
Mike
Old 08-17-2005, 07:35 PM   #17
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Doors
Got pictures of the blazer door with damaged spots and rusty areas?
Old 08-18-2005, 01:25 PM   #18
Musclerodz
Did some more checking, and the door has big harry crack at the upper hinge.
I have another door, but it is a converted pickup door. Some people say there is a difference, but I don't see it. Plus the assembly manual they sell shows you where to cut the doors for use on a Blazer.
Mike
Old 08-17-2005, 11:08 PM   #19
Blunova
Blunova's Avatar
Lookin for a centerlink?
69 C10
65 Chevy II
Blunova is offline   Reply With Quote
Old 08-18-2005, 01:26 PM   #20
Musclerodz
I'm lost. More description?
Mike
Old 08-17-2005, 11:26 PM   #21
zeusflash
zeusflash's Avatar
I'll take the fan and clutch. Let me know the total,I can do Paypal or MO/certified check. Let me know what you prefer.
'71 CST Blazer
'72 GMC 3/4 4x4
Old 08-18-2005, 01:29 PM   #22
Musclerodz
$27.50 shipped. paypal is much easier and faster. You have PM.
Mike
Old 08-19-2005, 05:30 PM   #23
Musclerodz
Fan/clutch is boxed but I can't get it out till Monday. I will send then.
Mike
Mike Redpath
Old 08-18-2005, 12:56 PM   #24
zachary2001
What Kind Of Deal Would You Make Me On The Used Blazer Tank And The Motor? Would You Be Up For Any Trades?
Old 08-18-2005, 01:32 PM   #25
Musclerodz
$250 for the pair. Trades depends on what you got. I have a short list in my first post, but I am sure I will need some other items along the way.
Mike
