Old 08-19-2005, 09:53 PM   #1
clean71
clean71's Avatar
What's this Blazer worth?
What do you guys think I should offer for this Blazer. Specs (According to Owner):
383 stroker built by Mark's Performance in Phoenix, AZ (750 Carter/ single plane intake/ 246 deg crane cam 556 int. & 556 exh. ~ 470 hp)
-jet hot coated hooker super comp headers
-3 " dyno max exhaust (extra set of custom made header mufflers go with it)
-hurst line lock
-4 whl disc by stainless steel brakes
-full auto meter phantom gauges
-t-56 6-spd from z-28 camaro
-centerforce dual friction clutch
-centerforce balance flywheel
-C5 corvette master cylinder & booster(big $)
-currently running elec. holley blue pump & regulator - & moroso elec. water pump (have brand new gm mechanical water pump and brand new holley mech. fuel pump that will go with it)
-elec. black magic fan
-hi amp alternator
-trunk mounted battery box
-custom hurst shifter and 6-spd knob
-dome light intergrated into roll bar/cage - 6 pt. roll bar/cage is welded to frame
-paint = GM color 7172
-original 12 bolt rear w/ 4.10 w/ Powertrax unit (big $)
-new 17x8 Amer. Racing Torq Thrust II's with 275/55/17 all around (set of 28" BFG DRAG RADIALS ON 15X8 CRAGARS GO WITH IT)
-grey rhino lining on bed - could use another coat or scrubbing
-grey buckets
-Sony am/fm w/ cassette with amp and kick panel speakers (good enough sound on the highway)
-polyurethane (PROTHANE - special order) motor/tranny mounts
-heavy duty sway bars and new poly. mounts on the rear.
-billet grille and clear marker lights
Pics:
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 08-19-2005, 10:32 PM   #2
dtlilly
dtlilly's Avatar
I hate putting a price on anothers property, but I would venture to guess, if the body is clean and no bondo, and everything else looks good, I'd have to say 10-12,000.
dtlilly is offline   Reply With Quote
Old 08-19-2005, 10:32 PM   #3
lowrider79
I bought a Trans Am that is supposed to have a Mark's Performance engine in it. The engine had 1500 miles on it and more than half the lifters had broken retainer rings, the timing chain rubbed the timing cover and after disassembling the block and checking the bores on the block they were out of round and the motor now needs to be line honed and possibly line bored. Is Mark's still in business? I have one of his business cards but the phone number does not work. Maybe it's a old card.
lowrider79 is offline   Reply With Quote
Old 08-19-2005, 10:33 PM   #4
cdowns
cdowns's Avatar
something about the way the front wheel sit in the wheelwell (not centered)looks funny??? how does it track down the road????
on a second look the rear wheels aren't centered in the wheelwells either!!!
Old 08-19-2005, 10:44 PM   #5
clean71
clean71's Avatar
I have heard good and bad things about MP's engines. Some people love em, some hate em. I think they still sell quite a few on ebay.
I think the lighting is what makes the wheel look funny. Front wheels always sit back a little in the wheel opening when lowered.
CPO U.S. Navy(Ret)
Old 08-19-2005, 10:53 PM   #6
lowrider79
Is it a internally balanced 383 or does it have a 400 damper on it?
Old 08-20-2005, 06:42 AM   #7
tnblazerk5
User #12137
tnblazerk5's Avatar
is there a alt on the motor , i cant see one or a place to put one for that matter and is that roll bar welded to the windsheild post i cant see down tubes on the front at the dash ? and whats up with that heater box ? and the wireing under the hood dont look the best to me and i agree with cliff about the wheels not looking correct in the wheel wells
tnblazerk5 is offline   Reply With Quote
Old 08-20-2005, 07:14 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
If that roll bar is welded to the windsheild frame like Rob and I think
it is, that would drop the value for me, JMHO, and I also agree with
just about anything else said above, as far as the wheels being off,
we need some more 2wd pic's for comparison , it might just be the
result of lowering it that far? I'm gonna say $8500, don't think that I
don't like it / wouldn't have it, I just wonder what else needs fixin?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-20-2005, 10:03 AM   #9
clean71
clean71's Avatar
Here's the pic of the alternator and a couple more pics of the front/side. I agree about the wiring (easy fix though), and the welded in frame is throwing me a little too. Not to big a deal if I was going to track it but if I want to fix it up a little for a dd may be different.
CPO U.S. Navy(Ret)
Old 08-20-2005, 11:50 AM   #10
tnblazerk5
User #12137
tnblazerk5's Avatar
i am going to have to go with craig and said around 8 to 9 thousand
is there any kinda top that goes with it ?
