08-19-2005, 10:46 PM | #1 |
72 chevy take off parts for sale or trade
HI All!
I have a few 350/AT/PS/PB/AC Take parts for sale or trade: Non clutch fan with bolts and cast spacer $20 good condition 2 PS Pumps 1 with cast bracket $30ea good condition 1 Stock Distributor with stock plug wires(wires are new) 1 Dual Point Distributor missing 1 condensor $50 2 rear brake drums turned, $25 both(I found a NOS set for mine) 2 rear step side fenders some rust around edges and marker light area rusted $150 both all parts plus postage from Pensacola, FL 32514 What I need: New POA Valve 1 Spare rim(no tire please) for dog dish hubcaps 1 Passenger exhaust manifold(curves back) New windshield glass rubber (no trim) Cruise lever for turn signal Thanks! Jeff Smith 3519 Gatewood Drive Pensacola, FL 32514 850-475-5030 mvpco@yahoo.com www.mvpc.com/1972chevy.htm |
08-20-2005, 09:40 AM | #2 | |
67 is sold
Hey Jeff.
Is this fan and spacer compatible with a 1968 327 with a short waterpump? If so, I'm interested. Quote:
08-20-2005, 10:24 AM | #3 |
Could I Get Some Pics Of The Rear Fenders And Are They Spare Tire Cut Out Or Not?
08-20-2005, 06:14 PM | #4 |
parts
Not sure if compatible with 327, it is a stock 350 fan out of my 72 C10
I will get pics also of fenders when I figure out how to post them, says files is to big. they do not have cutouts for spare tire. you can see some pics at http://www.mvpc.com/1972chevy.htm the red fenders are still on the truck in the pics, I have not removed them yet for the paint shop. Jeff |
08-21-2005, 08:42 AM | #5 | |
67 is sold
08-21-2005, 09:45 AM | #6 |
Parts
OK Sorry about pics, I thought link above would show fenders, I will try like I said above to figure how to post pics,
Fan spacer is 2" Rust on fenders is around bottom and where the marker lights go in, Jeff |
08-21-2005, 12:18 PM | #7 | |
67 is sold
Joe |
08-21-2005, 05:14 AM | #8 |
Tightwad
I would like to see some pics of the finders also and the rust spots you are talking about.
eric |
08-21-2005, 08:10 AM | #9 |
Born a Chevy Man
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
08-21-2005, 11:32 AM | #10 |
1972 Take off parts FST
Well I still could not post pics, says file to large.
So I made a website here is the link to the pics: http://www.mvpc.com/1972parts.htm Jeff 850-475-5030 mvpco@yahoo.com |
08-24-2005, 10:36 AM | #11 |
Active Member
Do the PS pumps have pulleys on them? I need the pulleys, only, but will buy the pumps to get them. Could you check the pulley numbers? I don't have my pulley number handy, but both are 72 350's with short water pump setups.
Thanks. |
08-24-2005, 02:33 PM | #12 |
Pulley Numbers
Pulley Numbers are:
3925537DC and 3860457CVGM $15 each plus postage of $3 each To: Jeff Smith 3519 Gatewood Drive Pensacola, FL 32514 850-475-5030 mvpco@yahoo.com |
08-26-2005, 09:20 AM | #13 |
Active Member
The ones that I am looking to replace are 3770509CE and 3993325DJ. Both are single groove, fit a straight shaft with a key, and are held on by a large nut. If your pulleys aren't mounted, could you measure the offset from the back of the pulley to the back of the hub and the pulley diameter? Both of my pulleys are the same dimensionally, but have different part numbers. Yours might work, but I need to know that before I buy them. If it's too much trouble to measure, I understand that, too.
Thanks. |
08-28-2005, 11:47 AM | #14 |
Pulleys
Pulley Numbers are:
3925537DC 3/16 inch offset and 3860457CV GM 1/2 inch offset I measured from flat spot on back of pulley and eyed it to back edge of groove. both are keyway and use large nut to hold on. $15 each plus postage of $3 each To: Jeff Smith 3519 Gatewood Drive Pensacola, FL 32514 850-475-5030 mvpco@yahoo.com Last edited by mvpco; 08-28-2005 at 11:49 AM. Reason: measurment |
08-30-2005, 08:28 PM | #15 |
Active Member
I think the 3860457CV may work. Could you lay a straight edge across the back side of the pulley and measure from the straight edge to the flat spot? That should take any "eyeballing" out of the picture. If it is close to mine, I'll buy it. I can always space things a little to get them to align.
Thanks. |
08-31-2005, 03:59 AM | #16 |
parts
3860457CV is 1/2 inch and the 3925537-DC is 3/8 inch
Jeff |
08-31-2005, 11:45 PM | #17 |
Active Member
Thanks for measuring. Mine are 5/8-inch and 13/16-inch; kinda makes makes you wonder "why so many different pulleys for the same engine..."
Thanks again. |
09-01-2005, 03:36 AM | #18 |
Pulleys
I agree, I went through a frustrating time adding power steering to mine then getting the right pulley to work.
Jeff |
