08-20-2005, 07:17 AM | #1 |
Dude...I'm a CHICK
"Pressurized Power Steering hose
Can some one please tell me the quickest, EASIEST way to change the pressurized power steering hose... Yeah, the one with the metal crimp thingies on each end, some one said its a "b!tch" to do. Any advice???
Thanks, junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
08-20-2005, 08:40 AM | #2 |
It just unbolts from the steering box and the pump. Use a good 6 point wrench to break the fittings loose. It is tight arond the fitting so you don't get a lot of room to work, which makes it a pain. Pull the old one out and bolt in the replacement. Add new fluid, start er up and chek for leaks and work air out of the system. I think mine cost like $20 at Orielly's. Took me about 2 hours, but I stopped to eat dinner in the middle. Heck you should not even need to jack your's up to get under it.
08-20-2005, 09:39 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I agree.It's only a pain because of it's location,not much room to work.
You work the air out by turning the wheel fully to each side about 10 times.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 08-20-2005 at 09:40 AM. |
08-20-2005, 09:50 AM | #4 |
It may help if you take in the old hose to compare, last time I got one for the K5 the one listed in their book was totally wrong.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-20-2005, 11:19 AM | #5 |
I just replaced my hose last weekend (PO had a 'custom' metal tube made ). But it wasn't really hard. I found that the best way to get the fitting on the box is to lay on the ground and go through the wheel well. The one behind the pump was also best reached from below. GL.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
