08-21-2005, 09:51 PM | #1 |
72 BB C30 Super LongHorn
1982 GMC Hydro-Boost Core
Anyone have a need for this?
It was from a 1982 1-ton dually Camper Special with a 454/T400 411 rear gears... It is a core, been sitting for a while and I am sure it will need to be R/R'd! Worth? Best offer takes it!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
08-21-2005, 10:21 PM | #2 |
1st take the master cylinder off,so its will fit in a smaller box.. And i would give you $35 shipped ? to 28705 Let me know,Interested...i could use that...Thanks,Erick
08-21-2005, 10:31 PM | #3 |
I dont know the shipping costs to you; I Use UPS...
www.ups.com ground to you by weight, box size, and zip code destination charges
08-21-2005, 10:38 PM | #4 |
I would say,about 15 lbs without the master cyl,14 inches long,8 wide 8 high and my zip is 28705..
08-21-2005, 10:45 PM | #5 |
Ok, well send that to me!
If the costs exceed reasonability, I will contact you first before shipping it! SOLD!
08-21-2005, 10:55 PM | #6 |
Pm sent...with info
08-21-2005, 11:16 PM | #7 |
For some reason I cant connect very fast right now, and I didnt see the PM...I will look a little later after I return from some eats!
Ciao!
08-22-2005, 01:10 AM | #8 |
too bad i didnt see this yesterday, i just threw away a good set of lines for an o ring hydroboost setup. if someone is interested in a hydroboost pump (with 2 return fittings) i believe i've got one laying around, might even have a set of brackets for a small block still attached to it.
08-22-2005, 01:15 PM | #9 |
Mine be a big block 454 I have a 80 burb 3/4 4x4 that is now a pickup with a 9 foot flatbed,454/400/205 1 ton with dana 60 and 14 bolt rears,4.10 gears and am using a 1/2 85 brake booster...I just hauled in a load,total weight of truck,trailer and cars...14,300 lbs. and the small booster just wont get it done here in the mountains...I am getting it piece by piece..Thanks,Erick
