08-22-2005, 12:55 PM | #1 |
(O.T.) never seen this before! (is it BS?)
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
08-22-2005, 01:25 PM | #2 |
Java Mechanic
It could just be the brevity of the ad, but I don't see how you can have ABS without wheel sensors and I don't see the point period if it doesn't isolate each wheel (which something that "bolts onto the master cylinder" clearly can not do.)
I would think that the benefits of something that simply pulsates the brakes with no consideration of the individual wheel to shaft rpm ratio is dubious, at best. I would want to see an independant lab test of the thing before I coughed up $450.00 for it.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-22-2005, 04:45 PM | #3 |
These guys have been to court for false advertising. Check this out... http://www.ftc.gov/opa/2003/07/brakeguard.htm
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
08-22-2005, 08:32 PM | #4 |
Just curious, but does anybody know what this "thingy" looks like?
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
