Engine ID ????
Previous owner preformed an engine swap in my '67 C10, now trying to identify and determine if it's a desireable block to rebuild, (not into mega HP, more into dependability).
Here's what I have--- Engine Casting: 3970010 Engine Date: J 30 8 (may be a 6, sure looks like an 8) Casting #: V1104TYZ Blk Vin: T7F711781 The intake and exhaust manifolds appear to have been switched out, retains the original 2V Rochester. If it happens to be a 350, is it possible to determine if it's a 2 bolt or 4 bolt without pulling the pan? Is it worth searching for a 350 block with the "010" and "020" stamped behind the timing chain cover? Thoughts on going with/rebuilding a 283 ? Thanks in advance for the help!!!!!!!!!!!!!!!!! |
www.mortec.com Could be any of the following...
3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
member #16
![]() Join Date: Dec 1999
TYZ= 1975 LS9 350Ci 165 HP 4bb c10-c2500
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 08-24-2005 at 04:41 PM. |
my gas saver
that is a good block to build. there is no way to tell if it is a 2 or 4 bolt until you drop the pan. 2 or 4 doesn't matter much anyway if it's built right.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
