08-27-2005, 11:57 AM | #1 |
troubleshooting nonworking fuel gauge
A guy I work with has a '79 chevy 4x4 1/2 ton with dual tanks, the gas gauge is pegged past full when the truck is running, shut truck off and it drops down to full until you start it again and it goes past full. I belive he said it does it on both tanks. Any ideas where to start looking? I would have done a search cause I'm sure this has been asked before, but am in a hurry. Thanks in advance.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
08-27-2005, 12:18 PM | #2 |
needin' money
i have heard that a ground could cause this
SWB Stands for Short Wide Bed |
08-27-2005, 03:06 PM | #3 |
definitely a ground issue by the tank. have you had the tank out recently?
08-27-2005, 04:31 PM | #4 |
I don't think he has had it out, whats a good way to check this? Could I clean a spot off on the frame and tank down to bare metal and run a wire between the two spots and see if the gauge works?
08-27-2005, 05:18 PM | #5 |
on mine mine goes to half way when i fill up ad somethimes its goes past half way and hopes around and when i get about a 1/4 tank it hopes arounds alot
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
08-28-2005, 08:44 PM | #6 |
So is the conclusion to make sure the ground is hooked up and both ends cleaned and it should work?
08-28-2005, 09:38 PM | #7 | |
needin' money
08-29-2005, 05:56 PM | #8 |
I tried running a wire from a bare metal spot under the tank to a bare metal spot on the frame and it didn't work. Maybe its gotta be grounded to the top of the sending unit and not just the tank. Or there is some other problem
08-31-2005, 01:02 PM | #9 | |
09-01-2005, 12:51 AM | #10 |
Professional Grade
Odd, my fuel gauge does the same thing.
However, one thing I have been thinking is that it may have something to do with a fault in the dual tank switch. Mine worked flawlessly by hooking it up to a bare wire I had running down my frame rail, until I pulled out the dual tank wiring, at which point I suddenly have the pegged all the time syndrome. Maybe try changing the switch out and see if that does anything for you? I'm just gonna run a new wire from my gauge to the back in my truck.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
