rear end swap question
I have a 14bFF that I would like to swap under my 69 K20 in place of the eaton. At the same time, I am going to put 2 inch lift springs all the way around the truck. What kind of geometry issues am I going to get myself into? This truck is going to be down to bare frame at the time, and i want to make sure I have this right. Thanks for aal your help
69 chevy 1/2 ton 2wd 72 GMC 1/2 ton 2wd |
Ask someone to move this to the 4x4 board, you get better responses over there when dealing w/ K trucks & lifts.
I moved it, I hope you don't mind. Let's see how it does in here.
1970 long fleet, 355 4 speed, primer, walnut goodies |
i cant find in 4x4 where this was moved to
I found this in the "Shop Safety" fourm
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
