Old 09-05-2005, 12:35 AM   #1
Streetmaster
What to do about a set of prefab doors?
I recently purchased a set of prefab doors for my 76 GMC, The doors are new but there not GM doors. I stuck them on but they fit kinda funny, as if there twisted. I tried every thing i could think of to make them fit right, but no luck. When i get the top to fit some what close, the bottom sticks out to much. Im about to pull my hair out, because the doors cost $100. bucks apiece. So if anyone knows how to adjust a door to make it fit better, i'dd appreciate the info.
Streetmaster is offline   Reply With Quote
Old 09-05-2005, 01:08 AM   #2
iceman7329
iceman7329's Avatar
Swap with me for some originals, were are you located?
iceman7329 is offline   Reply With Quote
Old 09-05-2005, 01:40 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Align the front to back and then get the bottoms flush. If the top still sticks out, open the door and use a 2x4 as a pry bar to tweak the top of the window frame in. If you stand the board up and put the bottom of the board through the window on the inside. Now you can push on the board and it will push the top of the window frame in toward the cab. Go slow until you get it where you need it....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-05-2005, 02:33 AM   #4
Streetmaster
ThanX guys for the responces, it seem as if you've done this before. I thought about doing that, but was affraid of door damage. Its almost as if the CO. that sold me the doors, had them all leaned up against one another, and it cosed them to buckle. But in anyevent (iceman7329) thanks for the offer, ill definentlly keep it in mind if i cant get mine to fit any better, beside i live in SW PA, about an hour south of Pittsburgh,PA.
Old 09-05-2005, 09:53 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
The stock doors on my 82 Blazer had a gap in them. I worked with the body man and he showed me how it was done. Go slow and you will see great results...
Old 09-05-2005, 11:42 PM   #6
a28doc
'87 V20 4x4
a28doc's Avatar
go slow and also might add putting an old blanket between the door and 2x4 it will help even out the pressure a little and keep you from marring the doors
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 09-06-2005, 07:52 AM   #7
bigarmzz
bigarmzz's Avatar
"beside i live in SW PA, about an hour south of Pittsburgh,PA. "
where abouts???
your probably not too far from me
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 09-06-2005, 08:18 PM   #8
Streetmaster
Im from a town called Uniontown, PA. Its about 22 miles from the WV, state line.
