Old 09-05-2005, 12:26 PM   #1
iceman7329
iceman7329's Avatar
Tilt Column
Can some one tell me if the tilt steering column in this link will fit in my 87 GMC truck. Thanks http://67-72chevytrucks.com/vboard/s....php3?t=169772
iceman7329 is offline   Reply With Quote
Old 09-05-2005, 12:31 PM   #2
setandreel
setandreel's Avatar
Don't think so, you won't have wipers
Mike
setandreel is offline   Reply With Quote
Old 09-05-2005, 03:16 PM   #3
iceman7329
iceman7329's Avatar
Ok, but other than that would it work, I can put in a new switch for the wipers.
Old 09-05-2005, 04:15 PM   #4
85X3
No dimmer either
85X3 is offline   Reply With Quote
Old 09-05-2005, 06:32 PM   #5
iceman7329
iceman7329's Avatar
Dimmer is on the floor. Was like that when I got it.
Old 09-05-2005, 06:34 PM   #6
iceman7329
iceman7329's Avatar
What I need to know is will it bolt in and steer my truck. Thats all.
Old 09-05-2005, 07:30 PM   #7
iceman7329
iceman7329's Avatar
Ok, I just found out from N2TRUX it will not bolt. Thanks for the help.
Old 09-06-2005, 08:00 AM   #8
the baron
the baron's Avatar
Hi all ,
sorry to hi-jack this thread but I have question :
will an upper bearing from a 1979 non-tilt column fit into a 1982 tilt column ?
I'm asking this because I still have a non tilt column in good shape , and I'm unable to find any reference number for the upper bearing that has to go into a tilt column ( mine is toasted )...
I asked this already once on this forum but I have never had any answer ...
many Thanks
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 09-06-2005, 08:30 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Baron,
If no one knows the answer here tak a look on Ebay. There are a couple of guys that sell rebuilt tilt columns for our trucks. I'm sure you could get the corrrect answer from them. One goes by steeringcolumnologist and I think his name is Wayne...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-06-2005, 10:29 AM   #10
85X3
Baron, I've got a few bearings, along with other goodies for tilt columns. I've found that it's best to replace both at the same time. If you are close to a GM Dealer, the PN is 7844651. You get the rack, bearings, and races.
Old 09-07-2005, 03:05 AM   #11
the baron
the baron's Avatar
WOW !
to N2trux & 85X3
Thanks a lot , I'll finally be able to fix that column !
So , you advise me to replace the two bearings ( upper & lower ) , I guess I'll do that ...
I have the 1980 GM Light Duty Truck Service Manual , with the whole procedure to open the whole column , looks like a nest of wires , needles , springs & other
As I never did it , will see if I'll win or loose
greetzzzzz
the Baron
Old 09-07-2005, 11:00 AM   #12
85X3
Do yourself a favor and get a lockplate depressor. Usually at NAPA on the Lysle tool shelf. Also get a pivot pin remover. Use a phillips screwdriver to release the tilt spring. The spring cap is the piece with a square hole. Push it in and turn counter-clockwise. I do tilt columns quite frequently. Piece of cake with the right tools.
Old 09-19-2005, 09:14 AM   #13
the baron
the baron's Avatar
Hi all ,
just to tell you that I got the column rebuild kit , my supplier was not sure it was still available , even with the right part number ...
Thank you all , this message board has shown again its value
Greetzzzzz
the Baron
