Old 09-07-2005, 03:38 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Found my Cam Problem in the Big Block
When I built my 454 I used a Comp Cam #11-207-3 this is a 270 duration cam with a 510 lift. It sounded like a solid lifter cam that was out of adjustment. I called Comp and told them my problem and they sold me another cam (same #) at cost and said to see if that fixed it. It DID NOT FIX IT, It still sounded nasty. After putting out $350 to have my lifter bores reconditioned and trying it again I Still had the same problem. I mean this thing was loud and nasty. A local machine shop said that they used that same cam and had the same problem in a few Big Blocks that they built. They said to use Comp Cam #11-242-3 a split duration 268 / 280 Cam with a 520 lift. The noise is gone and the performance is Sweeeet.
I called Comp and told them of my problem and that I wasn’t very happy after changing out the cam 3 times.
I'm waiting on there answer and will keep you all informed IF they call back
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-07-2005, 06:23 PM   #2
neonlarry
neonlarry's Avatar
And a lot of people say call the cam company and ask for their reccomendation. RIGHT!
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-07-2005, 10:27 PM   #3
steve_kibbe
steve_kibbe's Avatar
should have gone crane.............
Hope they make it right
steve_kibbe is offline   Reply With Quote
Old 09-07-2005, 11:38 PM   #4
Green Machine
Green Machine's Avatar
I think the magnum series was one of their earlier versions of more aggressive high lift cams, the xtreme series is newer and maybe more refined, I've run a comp and crane in my sbc with similar numbers, they both make noise, guess thats why the stockers have such long ramps, but yours must have been really bad, my next cam will probaly be a crane, not comp, machist told me of trouble comp had a few years back with base circle runout and quality control issues, as they farm out the grinding to some other companies, not sure if they do all there own now or not - just my 2 cents.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-08-2005, 07:05 AM   #5
arkracing
Weekend Warrior
How does the new cam sound as far as "lopeyness" is it nice or barely noticable?
I know it takes alot to make a big block shake...so i was curious as i have that cam in my 396 (that i haven't even started yet)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 09-08-2005, 10:04 AM   #6
1970 CST Short Wide
Senior Moment
It has a fair lope to it. I like it, but thats what I wanted. It comes on very strong on low end and holds though 5000 RPM
Pittsburg Ca
94565
Old 09-08-2005, 12:29 PM   #7
1970 CST Short Wide
Senior Moment
Comp just called to make sure warrantee guy had called. When I said he had NOT he asked me to send all my receipts to them. So I sent the $763.02 in receipts and we'll see what happens.
Pittsburg Ca
94565
Old 09-08-2005, 01:40 PM   #8
xtremer-pxl
xtremer-pxl's Avatar
that would be cool if they picked up the bill.
WANTED 2dr 4x4 fullsize blazer, yukon, tahoe
South Central Kansas Member
xtremer-pxl is offline   Reply With Quote
