72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Never really tried to locate this before. I knew it was somewhere, but it wasn't until I removed my cab off of the frame that I finally located it!
You will see in my image below that it is located under the cab on the top of the frame before the rear cab mount. All that was stamped was the : 2SXXXXXX The year, Plant build initial (I assume!) and the last 6 digits of the VIN... I am unsure on other years here from 67-71 but this is where mine is located on my 1972! Hope this helps someone! ![]()
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
Besides the Frame location and the metal VIN plate riveted on the door jamb, is there a stamped VIN on any of our Cabs?
My Camaros have them stamped on the firewall inside of the heater core cover. I have yet to find one on the cab on these trucks...Anyone? ![]()
![]() Join Date: Jan 2005
Don't know of any on the cab. My 68 has it stamped on the top of the frame, on the driver's side, between the motor mounts and the steering box.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
An American Soldier
![]() Join Date: Feb 2005
My 69 has it stamped the same place RicksTrucks mentioned.
Dan dan.brue@us.army.mil |
Merciless Butcher
My 67 is stamped on the frame under the cab on the drivers side as well as on the frame by the steering box. It was made at the Fremont plant if that makes a difference.
Your Bought And Sold....I Got Your Soul! |
![]() Join Date: Dec 2004
my 72 has it the same (on the front by the steering box,it took me awhile to find it,i had to have mine inspected and had to have 2 vin #'s and thats the only way i could get it tagged.you might check there as well
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#7 | |
![]() Quote:
I found the VIN stamped there on the top of the frame under the power steering lines! Thanx!! ![]()
its all about the +6 inches
I have always been told that they all had numbers in both locations, however, there was word on here a few years ago of 67's not having ANY numbers????
