07-03-2002, 02:55 PM | #1 |
took the heads off...look what I found
A bit of rust in one of the cylinders. I put the penetrating oil to it and it took it right off. Just have to use a 400 grit emery to remove a bit off the marking now.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
07-03-2002, 03:19 PM | #2 |
Was it just a gasket problem or is something worse wrong causing that problem?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-03-2002, 03:25 PM | #3 |
Looks like it was a gasket problem. Whoever did the work on this engine previously did a really bad job. So it looks like it's time for more of a rebuild than i was hoping.
07-03-2002, 04:38 PM | #4 |
Unregistered User
How long has it been since it was rebuilt? It sure is clean.
Mine had crap built up almost to the bottom of the intake.
71 SWB Stepside SB400/TH350 |
07-03-2002, 05:59 PM | #5 |
Led Sled! Discs R 4 ME!
Do yourself a favor dubie, and get the block and heads magnafluxed (sp?) before the rebuild
Doesn’t look to bad though unless a crack in the block or head caused the water seepage into the cylinder. |
07-03-2002, 06:12 PM | #6 |
its all about the +6 inches
That does not look right...
07-03-2002, 06:39 PM | #7 |
BTW, Are those "pits" in the top of the #2 piston?
07-04-2002, 09:36 AM | #8 |
No those aren't pits. It's just the pic. I will be taking the block to the local machine shop to have the cylinders honed and re cross hatched, might even go as far as going .40 over, dunno yet, gotta see how much $$$$ it's gonna run me. But it looks like this is gonna be a winter rebuild project. I was hoping to have it done this summer, but looks like it's postponed for 1 more year.
07-06-2002, 05:40 PM | #9 |
was the gasket steel or composite? if was steel then was probably original. if composite using no sealer then has been replaced
what heads casting number were on there ? date code ? |
