how do tell if your brake booster is bad?
That may sound like a dumb question but I just mounted a power brake booster on my 69 GMC (it had manual 4 wheel dsic brakes). I have ran this 4 wheel disc setup with manual brakes for the past year but just wanted to go with power. I got everything mounted hooked up and started bleeding the brakes (engine off). The brakes bled off good so I cranked it up to see how it felt but it didn't feel like power brakes, it was easier than engine off but was still kinda stiff like. I took the booster off of a 86 IROC and lengthened the brake rod going to the pedal. The master cylinder and prop valve are off a 79 caddy that I got the rearend from. It has front and rear disc brakes. I don't know if the booster is bad or something wrong with master cylinder. Is there any way to check booster? I have the vacuum line hooked up right, and there is vacuum going to the booster. Any ideas?
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
If your booster is working you will feel the pedal sink when you start the engine .
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
~Rest In Peace~
pump your brakes up first hold the brakes down start engine if pedals falls towards floorboard then its normal condition
when its hard to press the pedal down then the booster is shot
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
More Cowbell....
You know that big Oak tree at he end of the street, right before the boat landing???
Head straight for that...get up some speed....and press the brake pedal. You will know if it is working soon enough!!! (j/k)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Vacuum tool?
Can't you just use a vacuum checker tool and pump it up to about 20 inches of vacuum and see if it holds vacuum?
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
its all about the +6 inches
Things get trickey when you have a dual daiphram booster...any one have an idea on checking one of them? (bench testing)
It's a catastrophic success.
![]() Join Date: Jan 2003
My experiences with bad boosters, are that most times you can hear a vacuum leak(hissing or sucking sound)or the motor will go into a rough idle when the pedal is pushed due to the tear in the diaphram in the booster.
What is the diameter of the booster? If it is a small one from a car it will not perform as well as the larger truck ones...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
JHOW66 & 70BLOWNGMC: the pedal does sink some when the engine starts. I compared it with my wife's IROC and my pedal felt almost but not quite as hers felt before and after cranking the engine (my booster came off an 86 IROC)
PUTTER: so what you are saying if my booster isn't working the oak tree will stop me or the water will soften the stop? ![]() SNEAKYSNAKE: The engine doesn'tidle rough and you can't hear any hissing. The booster is off an 86 IROC Z28 and the master cylinder is off a 79 cadillac. It's possible the master cyl. could be stiff but not likely.
