Old 07-03-2002, 09:50 PM   #1
driveline_69
Question air condition cab
what is a 71 air condition cab worth? needs new floor and rocker panels put in. thanks driveline_69
driveline_69 is offline   Reply With Quote
Old 07-03-2002, 11:14 PM   #2
Low69CST
I take the front supports are gone, plus the back ones too probably? Doors? If it has no doors and the roof is perfect i'd say 150-200 tops. If its as bad as a few cabs i've seen, not even that much. We've scrapped alot of cabs. Its not that hard to cut out for A/C. Infact, you might be better to find a solid non air cab and use this one for a pattern.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
