Finally a Bulldawg
Distributor just won't go down
I can get my distributor to go in almost all the way but it just seems to stop about a 1/4" from the manifold. I played around with it until I got frustrate and just decided to ask someone more experienced than me to help. Are there any tips for getting it to go all the way down? This is only the second time I've dealt with distributors so any help is appreciated.
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
They can be tricky..... It sounds like the bottom of the distributer where it engages the oil pump is not aligned. You just have to pick it up and turn the roter and play with it untill oyu get it to slip in. What ever you do don't force it..... WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Progress = 0%
Just click the starter a few times and turn the engine over (with the ignition disconnected of course)..... it'll drop right down.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Semper Fidelis
Hey! I had this happen to me earlier in the year and I tried everything! What I had was a 307 that I was putting together from parts I had already. What happened is that I had a big block pump shaft in it and it sounds like what is happening to you. I had to take off the pan and put in a new small block shaft and it dropped in no problem. Good luck.
72 Chevy C 20 with 402 For sale 85 GMC K2500 ![]() 83 Trans Am Cedar City, Utah (Missouri Native) |
Semper Fidelis
also I figured this out by measuring up from the shaft to the manifold top edge.
Teufelhunden
i'm with wes and slammed on this one.
1971 K10 lwb fleetside 402 T350 205 |
#7 | |
![]() Join Date: Aug 2001
![]() ![]() Quote:
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 07-04-2002 at 10:37 AM. |
Just take a long screwdriver and put it in the drive rod slot and turn it to get alignment.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
Semper Fidelis
I agree with all of the above as long as you can rule out a big block pump driveshaft. They are different due to deck height. When I took mine out it was longer. When I put the correct shaft in it was lickety split! Good luck.
