Old 09-25-2005, 10:43 AM   #1
Hart_Rod
Hart_Rod's Avatar
Just completed front suspension rebuild / airbag install
I just completed installing ART bags, ART upper and lower Strong Arms, and converting front suspension to 5 lugs (ECE). Build sheet:
ART upper and lower Strong arms
ART Bags
ECE dropped spindles
ECE 5 lug conversion kit with drilled rotors/ master cylinder/ power booster...
PST sway bar & ECE lower sway bar mount
Misc parts from board members (drag link, tie rod ends....)
Hardest part: cleaning and brake lines!
Rob
Hart_Rod is offline   Reply With Quote
Old 09-25-2005, 10:45 AM   #2
Hart_Rod
Hart_Rod's Avatar
More pics:
Old 09-25-2005, 10:46 AM   #3
Hart_Rod
Hart_Rod's Avatar
more pics
Old 09-25-2005, 11:12 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks awesome! You need to write an article to go with the pics for the FAQ forum....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-25-2005, 11:18 AM   #5
bad_burb
bad_burb's Avatar
i was thinking of using this kit on my '76 burb. what are the advantages of the tubular upper and lower a-arms compared to the stock ones? is it worth the extra money to get new ones or just rebuild the originals? thanks in advance
bad_burb is offline   Reply With Quote
Old 09-25-2005, 12:30 PM   #6
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I was thinking of putting the ART uppers and lowers on my 92. How was the fit of there parts?
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-25-2005, 07:11 PM   #7
Hart_Rod
Hart_Rod's Avatar
N2TRUX - I have plans to write some more when I find time. Did you ever send me more pics of your truck? (robhartley@aol.com) What about a price? Also, do you have pictures of how you connected/routed your front air bags? I would like to get some thru frame fittings, do you know a good source?
Bad_burb - I believe they will allow you to go lower and still be able to align the front end correctly (http://ridetech.com/productinfo/controlarms_trucks.asp). If you want to run a sway bar, you will have to upgrade to one the uses end links.
Phantom_Dually - Fit was really good, however I suggest you check your parts boxes really well, as my shipment was missing some "small" parts, uhhh, like the lower a-arms!!!!! Other than that everything fit well.
Rob
Old 09-27-2005, 12:09 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Hart_Rob
Bad_burb - I believe they will allow you to go lower and still be able to align the front end correctly.....
That is the main advantage from everything I have read. Besides they look cool!
N2TRUX - I have plans to write some more when I find time. Did you ever send me more pics of your truck? (robhartley@aol.com) What about a price? Also, do you have pictures of how you connected/routed your front air bags? I would like to get some thru frame fittings, do you know a good source?.....
I haven't sent any pics yet. I thought I would wait until the motor is finished. Here are a couple of pics but I don't think you can see how the lines are routed. We drilled holes and put grommets where they pass through the crossmember. I'll see if I can't find a company that makes the through the frame fittings for air....
Old 09-27-2005, 01:31 AM   #9
Rollie396
someday it will be done!
Rollie396's Avatar
here's what I used.I got them at a local rig supply store.Well worth the money IMO.(the bulkheads are in the top baggie in the pic of the fittings).Tossed in a pic of the underside of the plumbing too for the heck of it.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 09-26-2005, 11:08 AM   #10
fletch4x4
fletch4x4's Avatar
Got any pics of the whole truck? and how low does it get you
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 09-27-2005, 08:23 PM   #11
Hart_Rod
Hart_Rod's Avatar
Are those compression fittings?
Rob
Old 10-06-2005, 09:17 AM   #12
Hart_Rod
Hart_Rod's Avatar
More pics:
http://67-72chevytrucks.com/vboard/s...95#post1431695
Old 05-02-2007, 03:54 PM   #13
edflores
Re: Just completed front suspension rebuild / airbag install
ART Bags
Rob
does the spring pocket already have holes for the upper air spring plate to go or do you have to drill them?
edflores is offline   Reply With Quote
Old 05-02-2007, 04:22 PM   #14
gringoloco
A guy with a truck
gringoloco's Avatar
There are holes in the plate. You must drill the truck.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-02-2007, 05:54 PM   #15
edflores
just the 4 outers right? i bought my brackets from ***************** but they didnt come with the bolts/nuts. hmm.
Old 07-14-2008, 12:17 AM   #16
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I know I'm digging here, but what kind of sway bar is that?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-14-2008, 03:03 PM   #17
Hart_Rod
Hart_Rod's Avatar
I got it from PST (performance suspension technologies)
Old 07-14-2008, 02:50 PM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work Rob!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-14-2008, 07:07 PM   #19
jlaird
jlaird's Avatar
Looks good! I don't know how low you are planning on going so this may be a non-issue for you, but you got the old style ART arms with the shock mount positioned below the arm. The new ones have the shock mount above the arm. Just wanted to let you know in case this might become an issue for you in the future.
josh
jlaird is offline   Reply With Quote
Old 07-14-2008, 07:36 PM   #20
Hart_Rod
Hart_Rod's Avatar
josh
I definitely drug them a few times, . I like to think I had a little to do with them changing the design, because I called and complained about it. I got 2 new brackets and will be modifying them soon. Thanks for asking. Take care.
Rob
