Old 09-25-2005, 12:43 PM   #1
shifty
Questionable
shifty's Avatar
Ls1 swap: letdown of the day #1
Talk about a bummer. Take the front clip off, go to line up the engine and tranny to figure out where to drill holes for the mounts, get it all in there and ... got a fight between the A/C compressor and the Alternator. Frame rails are a bit too tight. Would be a major pain in the ass to remove, drop the engine in and remount it (trying to get to the bolts would be a major B$#CH once it's mounted).
I guess I'm going to flare out the driver's side framerail same as the passenger's side, thinking that might give me enough room to slide it in. Dunno how to do that yet.
Pics:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-25-2005, 01:01 PM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
It's hard to tell by the pics how much it would need to be bent/flared out to make it fit. If it's a considerable amount of material from the frame, I would give some thought to cutting and boxing that small portion of the frame.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 09-25-2005, 01:09 PM   #3
masterbeavis
Having issues
masterbeavis's Avatar
Heh, DOOH!! I am thankfull on the truck motors all of the bulky stuff is on top of the motor At least that is one problem I wont have to deal with.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-25-2005, 09:16 PM   #4
FirstGen
Just Don't Stop!
FirstGen's Avatar
There are a few alternator relocation kits out. I know I've heard of a few. Do a search on ls1tech.com and you are sure to come up with a few options if that is what you want to do.
Personally, I would remove the alt or compressor and deal with re-installing it after you get the motor mounted.
I had the same issue with my ac compressor with the truck motor. They are in the same location. The truck a/c compressor is a tad bit smaller though which I thought seemed backwards...
Goodluck,
Taylor
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 09-26-2005, 10:12 AM   #5
shifty
Questionable
shifty's Avatar
PS, there was a letdown of the day #2 - it basically revolves around what happens when your thumb gets sandwiched between a framerail and a 750lb engine+tranny.
I had to drain the blood from under my nail in several places on the thumb yesterday to relieve pressure. It ain't purty
Old 09-26-2005, 10:19 AM   #6
FormerMember
OUCH! I know how that feels and it's NOT fun. Neither is growing back a thumb nail.
What are you doing putting your digits in there???
I agree, I would yank the accessories off and deal with just the block.
FormerMember is offline   Reply With Quote
Old 09-26-2005, 10:31 AM   #7
FirstGen
Just Don't Stop!
FirstGen's Avatar
It's ok, the ladies dig a battered man.
lol
TT LSA/6L90e/9"
Old 09-26-2005, 11:07 AM   #8
shifty
Questionable
shifty's Avatar
LOL, I wish that was true about the battle wounds. After hacking out a city block's worth of kudzu vine this weekend and working on the engine, my hands are blistered and battered. My woman ain't too keen on it and thinks I'm falling apart
I'm going to take off the A/C compressor today or tomorrow and try again (still gotta drill out my mounts...this ECE kit is pretty nice). A/C compressor only takes four bolts through the side IIRC. I'll try to reinstall it once it's in, although I'm not sure how lucky I'll get. If nothing else, I'll buy a delete kit for the A/C compressor for now. I just didn't want to wait any longer
Setbacks, setbacks, setbacks...
Old 09-26-2005, 11:25 AM   #9
FormerMember
Always, when re-engineering a 30 YO vehicle with new schtuff.
hang in there, it's always fun when it's together and you're burning rubber.
Old 09-26-2005, 12:39 PM   #10
panhandler62
Java Mechanic
panhandler62's Avatar
In the long run.... you might not want the alternator down there in the puddles and all anyway.
It might be a much happier situation to look into a relocation kit or custom brackets to get the accesories up top.
On other fronts -- unless you are accomplished at thumb - wretling gorillas -- it's not likely that you can grapple an engine into place by hand. Keep them digits clear! LOL
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-26-2005, 01:00 PM   #11
cdowns
cdowns's Avatar
maybe a smaller diameter alt is available???
Old 09-26-2005, 12:57 PM   #12
shifty
Questionable
shifty's Avatar
Yeah, I agree, I looked into a relocator at ls1tech, but all I could find is stuff that the guys with turbos are using and the only one that was reasonable ($125) comes from QMP (quarter mile performance) and they may be out of business - website is down and a lot of people had bad dealings with the guys who own it.
I want to keep it clean and as close to stock on the new engine as possible, if the alt moves, I gotta change the harness.
As for fingers in the way of the engine - when you're rocking and tweaking and dropping something like that in by yourself on a 30yr old truck (), sometimes things get shoved where they shouldn't be
I'll be happy when the engine, tranny and crossmembers are all bolted up. The rest will seem like a cakewalk. Electric fans should be here by friday. All that leaves is pedal setup, fuel tank-pump-lines setup, shifter positioning and cutting the hole in the floor, gauge setup, PCM reprogramming and wire harness reconfig. That'll probably take at least a month. Oh, and my heater core is busted also, but that's chump change compared to the rest of this stuff
Old 09-26-2005, 01:05 PM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
All in due time!
TT LSA/6L90e/9"
Old 09-26-2005, 01:16 PM   #14
FormerMember
Aren't you glad you removed the front clip afterall?
That would've been your elbow that got gacked.
Old 09-26-2005, 06:21 PM   #15
shifty
Questionable
shifty's Avatar
You don't hafta tell me! I'm grateful for sure I followed that advice. Last thing I'd have wanted was to go through that nonsense with the front clip on. It would have never happened.
If you note the frame above, you'll see the manual gearbox is gone as well. I got rid of it and took an old one to get cored, bought a new one (OEM refurb - Cardone) and pitman arm from Advance for $180 (pricematch to Auto Zone made it cheaper). That's going in as soon as I get the drivetrain mounted.
Old 09-27-2005, 12:06 AM   #16
incoma
incoma's Avatar
I test fit a 5.3L in my truck a few months...no wait 1 1/2 years ago. The accessories from a truck will fit right in. I think there's a bit of tweaking needed for the p/s pump, but it did fit. Perhaps you just need to find the brackets from a truck.
FirstGen - didn't you have a truck engine and brackets in yours? Unless you built a custom 6.0..
incoma is offline   Reply With Quote
Old 09-27-2005, 12:15 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Nothing a little grinding won't fix......
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2005, 12:37 AM   #18
shifty
Questionable
shifty's Avatar
hey N2, what's that a frame for? (other than that, you got any info on the suspension? i notice the brackets on the side there)
Old 09-27-2005, 03:12 AM   #19
Redaddiction
LS1 Lover
Sorry to see you are having trouble already. I'm glad I'm using the truck brackets they mount the alternator up high the same for the corvette's. I know gm sells the brackets for a fairly cheap price by gm's standards but if do decide to move to truck accesories nothign will fit from f-body the accesories are all spaced differently.
I say have a machine shop make you a bracket to move the alternator or get a smaller one. On the ac compressor you might be able to use a truck one and bracket and change the pully's up I have one laying around if you need any measurements etc or if you need some parts to test fit I can send em to you I have a bunch of odds and ends you can borrow to help you figure stuff out.
Redaddiction is offline   Reply With Quote
Old 09-27-2005, 09:13 AM   #20
guyryan100
guyryan100's Avatar
Keep in mind that alternator will one day need replacing and you're not going to want to pull the front clip and engine to change the alternator!!
guyryan100 is offline   Reply With Quote
Old 09-27-2005, 09:45 AM   #21
Americanrider
any help here?
http://www.classicperform.com/tech_a...ngine-Swap.htm
Americanrider is offline   Reply With Quote
Old 09-27-2005, 10:08 AM   #22
shifty
Questionable
shifty's Avatar
Originally Posted by Americanrider
Not much help, but an idea. Never thought to use a 99+ oil pain instead of the F-Body oil pan. Should make sliding things in a lot easier.
Old 09-27-2005, 10:10 AM   #23
Yukon Jack
Yukon Jack's Avatar
Hang in there and take your time deciding the best fix for this problem. I ran into so many unexpected problems with my swap but with time and thought, everything will work out.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-27-2005, 09:13 PM   #24
70 shorty
Where's my beer?
70 shorty's Avatar
I have no specific advice to your swap, but I also wanted to add that remember whatever you come up with, just make sure it will fit with the front clip back on.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 09-27-2005, 09:33 PM   #25
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Here's my solution to a similar problem with the LT1 swap I did in my 68. I notched both sides of my frame to clear the factory compressor and the York air ride compressor. Hope this helps. Later, Mark
FuelCellGuy is offline   Reply With Quote
