09-29-2005, 10:02 AM | #1 |
motor size?
i just bought an 1971 chevy c-10 pick up the owner told me he thinks it has an 305 or 327. I know that anything from 305 -350 are the same blocks. can anyone tell how to adentify the motor so i can order parts for it?
09-29-2005, 10:18 AM | #2 |
A.K.A- Crummy
Can you locate the casting #'s? http://www.mortec.com/castnum.htm
2003 Silverado Z71 Are fishermen all liars? Last edited by 1969 C/K CST; 09-29-2005 at 10:20 AM. |
09-30-2005, 07:23 AM | #3 |
no i couldn't find te numbers although i know it is the orginal engine for the truck
i did find out from the vin numbers that the motor is a 2barrel carbed 350 i got the manifold for a 4 barrel carb to go back on it |
09-30-2005, 08:41 AM | #4 |
FYI,if it wasn`t a 350 it would have been a 307.The 305 came out later.Welcome to this site and enjoy!
09-30-2005, 09:17 AM | #5 |
FYI also...the 305 block is different then a 350 block. The bore on a 305 is much smaller and it can't be over bored to 4" to make a 350.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-30-2005, 09:32 AM | #6 |
if its truly OE then its not a 305
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
09-30-2005, 12:04 PM | #7 |
My money is on the 307 - they were super common...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
10-06-2005, 11:49 PM | #8 |
i know for a fact its not an 307 because the 307s have the plugs pointed toward each other and mine aren't
10-07-2005, 06:41 AM | #9 | |
1968 Chevy 4x4 307 4 speed |
10-07-2005, 07:52 AM | #10 | |
Kirk |
10-07-2005, 05:10 AM | #11 |
1971 Chev Service Manual lists -- 250, 292 Cu.in - 6cyl and 307,350,402 cu.in - V-8's
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
10-07-2005, 10:21 PM | #12 |
if the plugs point at each other. isn't that 2:02 angle plug heads?
Pat ______________________ 1968 1 Ton Dually Flatbed 327/th400 1968 C30 Open Road 327/th400 1997 F350 CREWCAB 4X4 460 BIGBLOCK |
10-07-2005, 10:33 PM | #13 |
How do you tell the difference between a 307 and a 350 besides the numbers on the block ?
I have a block in the garage, and I looked the numbers up in a book I have. The information I get is it is either one. So I need to know another way to check. |
