10-03-2005, 11:52 AM | #1 |
3 speed adjustment ?
My question is about the adjuting the linkage between the column and the rods going to the transmission. the piece in the column does not always engage the rods. I tried to turn the ring that is held to the column by the single bolt and that helped a little but it still miss most of the time. Any help would be welcome. I do not want to buy a gnome to ride under the hood to help me with my gear changes.
10-03-2005, 01:28 PM | #2 |
Check your pivot points. You might have to change washers. You might also want to grease your pivot points. I had alot of problems so I moved to a floor shifter instead.
10-03-2005, 02:21 PM | #3 |
It's a catastrophic success.
If you have loosened and adjusted the bolts and plate at the bottom of the column and its still sloppy your probably due a swap or rebuild.
10-04-2005, 02:39 PM | #4 |
If i choose to rebuild are the parts i will need still available. My truck is a 3/4 ton 4 wheel drive if i decided to go the floor would the trans hump from a 4 speed work with out any modification. thanks for the input so far.
10-04-2005, 11:37 PM | #5 |
Questionable
if nothing else, i'll sell or trade you mine for a tilt or straight column without the 3spd linkage and collar. mine was still in good shape and i am moving to a 6spd on floor and power steering, so i don't need it. i'll reimburse you with cash + my column if you can score one in excellent shape
pics: http://www.satellitehead.com/uploads/front_clip02.jpg http://www.satellitehead.com/uploads/front_clip03.jpg
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 10-04-2005 at 11:38 PM. |
