Old 07-06-2002, 03:18 AM   #1
Jefe
Jefe's Avatar
Question Switching to HEI...wiring question
350 in a 68 Chevy SWB. Have a points distributor in there now...going to switch to HEI soon. Question is...do I have to run a hot wire straight from the fuse box to the new HEI coil? or can I make a new connection out of existing wire that plugs on to the - side of the old external coil from the wiring harness? Now this wiring harness that is on there now is only about 2 months old, bought it from Rick's. Also what gauge should the wire be?
Thanks again!
Jefe is offline   Reply With Quote
Old 07-06-2002, 07:30 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The wire in your harness is not a full 12 volts. The new HEI needs 12 volts. Just run a wire from the ING UNFUSED location and plug it into the new distributor.
Old 07-06-2002, 08:32 AM   #3
71Chev
71Chev's Avatar
Put a 5 amp inline fuse in that new wire also.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 07-06-2002, 09:27 AM   #4
REPO1
Shortbox wanna-be.
REPO1's Avatar
Yup, I second that. You cannot use the stock wire, as it is a resistance wire. You must run a new 12 guage wire directly to your fuse box.
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 07-06-2002, 10:31 AM   #5
RipMeyer
RipMeyer's Avatar
Click Here For Complete Instructions In The FAQ Section
RipMeyer is offline   Reply With Quote
