Old 10-09-2005, 07:08 PM   #1
sledgehammer
Question which master cly. to use
i have a 69 c10 that i am still using drum brakes on front for time being, i have a booster,master cly.,porp. vale off 71 with disc. my ? can i use booster,mst. cly. for 71 and 69 porp. valve for better braking until i change over to disc setup. i know there was a thread on this, i have saved a bunch of threads but not this one and been searching for days. thanks for all the help
sledgehammer
sledgehammer is offline   Reply With Quote
Old 10-09-2005, 07:19 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It may work, but I would advice against it. Discs require a much higher working pressure than drums do.
Old 10-09-2005, 07:36 PM   #3
sledgehammer
i thought i could use booster-not sure which mst. cly.,,porp valve for frt. drum setup. i must have been dreaming. thanks for reply longhorn man.
Old 10-09-2005, 09:21 PM   #4
guyryan100
guyryan100's Avatar
just put on the new booster and don't mess with your m/c or prop valve for now. booster will work fine.
guyryan100 is offline   Reply With Quote
Old 10-09-2005, 10:58 PM   #5
sledgehammer
thanks for the help guys. i have been working on this ole truck for a while,gettin ready to put her on the road. wiring was a nigtmare but got all that redone as well as cam and bottom end of engine.
hammer
Old 10-10-2005, 04:10 AM   #6
jlmtrout
You'll also need a longer brake rod from the brake pedal. Manual power brake master cylinders have a deep hole in the end of the master cylinder and require a longer pin that power disc brakes, which have a shallow hole. Since you got everything off of a disc brake donor, you should already have the short pin. Good luck and keep on truckin'..............Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 10-10-2005, 07:01 AM   #7
jlmtrout
When I said manual power brakes, I meant to say power drum brakes. You know what they say about getting older, the first two things to go are your eyesight,and ....Uh.....I forget what the other one was. Good luck and keep on truckin'....Jerry
Old 10-13-2005, 07:26 PM   #8
sledgehammer
jlmtrout, ya im with ya on the older thing also i have gotten the drake setup figured out with the help of you and longhorn man. guys i appreciate the help.
hammer
