Old 10-09-2005, 07:31 PM   #1
mx jim
making a noise need HELP??
I have a 70 chevy 4x4 short bed and it makes this noise/vibration and i can't fiqure it out. When i am driving at about 60-70 mph and i slitly turn right it will it make a noise and vibrate. Only when turn right it does it. It does NOT do it when i am going strait or turn left though. So for i have changed the front wheel bearings and the ball joints and rotated the tires and it did not help the noise/vibration at all. So i am not sure what els to do.
Thanks for all the help James
mxjim 1970 chevy 4x4, 400 small block, 4" pro comp lift, with 35s.
mx jim is offline   Reply With Quote
Old 10-09-2005, 09:50 PM   #2
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Maybe check for steering tire rub marks around the front end stuff. Good luck.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 10-09-2005, 10:52 PM   #3
Mudder
Mudder's Avatar
Left rear axle bearing. Check it.
Mudder is offline   Reply With Quote
Old 10-10-2005, 09:03 AM   #4
How`s the exhaust hangin`.Might sound silly,but I`ve found that to be the problem a few times.
Old 10-10-2005, 11:08 AM   #5
mx jim
I will have to check the wheel bearing that mite be it. I will also have to check the exhaust out. I work in a exhaust shop so that should be easy to check. thanks for the help
