10-09-2005, 10:10 PM | #1 |
Windshield removal
So, how tough is it?
10-09-2005, 10:20 PM | #2 |
cut the gasket!!!!!!!!!!!!!!!!!!!!!! I broke a nice one trying to peal the gasket!!!!!!!!!!!!!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-09-2005, 10:23 PM | #3 |
Are you going to save the glass or rubber ? I would use a new rubber gasket, then just cut the rubber near the glass on the outside and carefully push out, if you want to save the rubber, work it loose at the top corner while pushing out on glass, start one side then the other, work toward center while pushing on glass, you will need a helper or two, glass is pretty tough, doesn't break real easy.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
10-09-2005, 10:31 PM | #4 |
Yep..cut it out.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-09-2005, 11:00 PM | #5 |
no brain no headache
i cut the gasket out on mine too. What i did was lay the razor flat on the glass and traced around the window cutting off thelip that covers the glass then it pushes out.
same way with the rear window.
1996 GMC Sierra z71 1970 SWB 2wd (project) |
10-09-2005, 11:04 PM | #6 | |
Heh, I also need help yanking the front clip off (it's unbolted) and getting the BBC out (it's unbolted too). The pregnant wife is no good at it... |
10-09-2005, 11:07 PM | #7 |
I would but thats a long trip
Tempting though
1996 GMC Sierra z71 1970 SWB 2wd (project) Last edited by 70c10swb; 10-09-2005 at 11:10 PM. |
10-09-2005, 11:23 PM | #8 |
i did it myself in 20 minutes
putty knife, kinda sharp hammer remove the trim carefully, start at a corner. cut the gasket inside or outside. most would say inside so you can just push the glass out. basically it's like removing the differential cover. just hammer alond the border with a putty knife and hammer. |
