Another Manual Steering Box Question
The interchange on a manual steering box for my '72 C-10 as I understand it is '68 to '87 (Remember, I am staying with MANUAL).
My question is: What makes a '67 Manual Steering Box not work? (As luck has it, I have one of these available on a parts truck). Any info would be appreciated. |
No idea, but if you need one, I have a 71 manual box with a really good pitman arm on it.
Questionable
I may have offered before, if so, forgive me. I have a '68 manual gearbox with pitman arm in great shape also. I think there are only bearings in there with a wheel and grease. I'm not entirely sure. I just heard to be careful when you crack em open because bearings will roll all over the place.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() ![]() Join Date: Jan 2005
The only thing I've heard about '67 frames is that they don't have a dimple in them that is required for mounting a power steering box, and some people have run into problems when they try to mount a power steering box on a '67 frame. I had a '67 truck (definitely a '67 because the VIN on the frame matched the VIN plate) and mounted a power steering box from a '76-ish truck on it with no problems, so I'm a little confused about this dimple issue. If a newer gearbox fit on my '67, I can't see any reason why a '67 manual gearbox wouldn't work on a '68-'72 frame, although I have never actually tried. I removed a manual gearbox from a '70 frame, and as far as I could remember, it looked the same as the manual gear box I removed from my '67.
The 67 box should be the exact same. There was some goofy stuff with the power steering in 67 that used a manual box, so perhaps that is why it says that. When I bought a 71 complete front end to put under my 67 it had a manual box that was the exact same as my 67 box.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
its all about the +6 inches
Bill, I was thinking about this question the other day from when you asked last week... and in all reality, I think you may be right...the older ones may well go on there.
Appreciate the info y'all.
#8 | |
![]() Join Date: Feb 2002
The manual gear box on my '68 C/10 pulls left-to-right, and looks like a smaller version of the hydraulic Saginaw P/S gearbox. Don't let the body style fool you, the '67s are more closely related to the Task Force trucks ['66-'58] at least in the steering end.
