10-11-2005, 12:07 PM | #1 |
needin' money
crossmember
does anyone make or sale dual hump crossmembers, the ones to where you can run dual exhaust without having to go under on one side, and above on the other, i need one cause these headers when trying to hook up the exhaust hit it, so it won't bolt up
SWB Stands for Short Wide Bed |
10-11-2005, 12:43 PM | #2 |
Someone on here was making x members that would clear duals. That was about a year ago, so I don't know if he finished them or not.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
10-11-2005, 12:54 PM | #3 |
*Proud Member*
i have a '75 2wd and i took two stock cross members, cut both in half and put them back together. sorta like this:
10-11-2005, 12:55 PM | #4 |
www.73-87chevytrucks.com
I hope to be offering one sometime.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-11-2005, 03:56 PM | #5 |
75stepside good idea i think i might do the same mod i like it better that way b/c it appears to be removed easier than the old one seeing how all you have to do is unbolt the bottom bar (seven bolts counting the tran mount) if this is correct please let me know if there is anything i need to look out for before i do this to my truck i really like it thanks 86 gmg
square body trucks an addiction or an investment either way they consume all my extra time and money |
10-13-2005, 01:12 PM | #6 | |
*Proud Member*
You probably could remove the cross member as you have stated, although i think you'd want to remove it completely and it would not be that much more difficult. The only drawback to doing the mod as i have is #1. I had to grind off one E-brake cable guide (although its not too hard to fab one up and bolt it on the frame. #2. If I recall correctly, I had to drill 2 holes in the drivers side frame... no big deal, but it had to be done. |
10-11-2005, 05:58 PM | #7 |
You could also just get a 73-74 trans crossmember that looks just like the one 75 stepside made.
This is my stock one 3rd from the left: Found one of it installed:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 10-11-2005 at 06:04 PM. |
10-11-2005, 08:26 PM | #8 |
needin' money
so if i find a 73-74 i can just get one off of it, dies it matter, 1/2 ton,3/4 ton, or 1 ton
10-12-2005, 12:27 PM | #9 | |
10-11-2005, 08:33 PM | #10 |
needin' money
or explain to me how to build the crossmember
10-12-2005, 10:24 AM | #11 | |
Happy to be here
10-11-2005, 08:40 PM | #12 |
The one on my 87 looks like that one Captkaos posted
10-11-2005, 08:52 PM | #13 |
Professional Grade
I just got one from a 75 with an SM465. Direct bolt in with tons of exhaust clearance room.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-12-2005, 12:09 AM | #14 |
Heres the one I made last winter. I think summit has one pretty similar...corn
10-12-2005, 12:52 PM | #15 |
so apperantly the crossmember really is there to mount the tranny to only or is it not a little bit of support from side to side as well? i am just picky about not sacruficing stability sorry my spelling sucks
10-13-2005, 03:10 PM | #16 |
well since i dont have an e brake due to the ford nine inch rear with disc they wouldnt hook up sooooooo that not a problem and as far as drilling holes its in a bare frame right know and the original tranny was a 700r4 so drilling hole anyway to fit the 350t thanks for the help
10-13-2005, 03:33 PM | #17 | |
*Proud Member*
10-13-2005, 10:29 PM | #18 |
needin' money
i got a 12-bolt with a working e-brake (worked last time i used it)that is hooked up
10-14-2005, 09:10 AM | #19 |
yea i just purchased a set of wheel chocks and cary them in the tool box and use them when on a hill
