Oil Pan Removal ?
Can the 350 CI oil pan be removed on our trucks, without lifting the engine up or out completely?
1997 GMC Sierra Ext 1965 Mustang |
67 is sold
Re: Oil Pan Removal ?
I was told it has to come up a few inches at least
![]() Just unbolt the two mounts, the trans mount and lift a little |
I think you can if it is a 4 wheel drive but other wise you have to un-bolt motor mounts and trans mounts. Just take the bolts out that go through the frame then put a bottle jack under the balancer then put a 2by4 inbetween the mount and frame and take the inspection cover off. Then you should be able to get the pan out.
#4 | |
Don't take the trans mount bolts completely out, just back them out 1/2" or so and it will give you enough play to raise the front up plenty. I'd use a cherry picker to lift if available. Bottle jack and 2x4 prone to give ya problems, don't ask me how I know. Kirk |
#5 | |
~Rest In Peace~
the problem would be bearings get wiped out and pressure on the crankshaft isnt good for it too ![]()
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
That's what I was afraid of.....thanks for the info. That's what I'll have to do then........
Professional Grade
Make sure you secure the engine once you've lifted it. You can very easily loose fingers if a bottle jack fails while you've got your fingers up there.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
![]() Join Date: Sep 2005
jack it up and take an 2x4 and cut an slit in it for the bolt and place it in between the motor mount and frame it will hold engine up
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
be careful of the distributor cap if it is close to the firewall or you might crack it before you realize it.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Unbolt the fan shroud too or you will crack it when you jack the engine.
