-Chris
![]() Join Date: Sep 2002
Vin number question
My Vin # is "CE140B108451". Can someone help me in decoding this so I can learn a little about my truck. Thanks, Chris.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
Re: Vin number question
CE140B108451
C= conventional cab E= eight cylinder 1 = 1/2 ton 4 = with a box 0 = 1970 model year B= Baltimore assembly plant the rest is sequence number
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 10-21-2005 at 11:50 PM. |
Active Member
CS147Z136220
How bout this one. Let me see if I got the hang of this. C = Conventional cab S = six cylinder 1 =1/2 ton 4 = with a box (if it's step side what would the digit be? are there other options? 7 = 1967 model year? Z = what assembly plant? Thanks
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
![]() ![]() Join Date: Jan 2005
Z = Fremont, California
The model code (not the VIN) will tell you what kind of bed, etc. you have. You can find the 5-digit model code on the glovebox sticker. |
yah 7 was the year is this style vin..and Z fremont plant. You almost got it,
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
