Old 10-24-2005, 01:19 AM   #1
squeekyM
Jumpy Speedo
Hi Everyone,
I was wondering if anyone has dealt with a jumpy speedo before? Between the speeds of 40- 70 mph, the speedo jumps back and forth, and sometimes seems to skip (like when traveling at atleast 65-70mph it will read someone around 40-55). Any ideas of why this could be caused?? Thanks.
- Jerry
squeekyM is offline   Reply With Quote
Old 10-24-2005, 01:34 AM   #2
sdkid
Re: Jumpy Speedo
Unhook the cable from the back of the cluster. Pull the cable from inside the casing. clean it and coat it with some white lithium grease, and reassemble. See if that helps. You don't want any of the grease in the back of the speedo head. If this does not help, it may be internal to the speedo head itself.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 10-24-2005, 03:00 AM   #3
Americanrider
Re: Jumpy Speedo
Lube it or lose it as they say....
The jumping needle is caused by the cable binding up inside the cable casing, once it frees itself from the bind it will spin faster to unwind the twist put in, then bind up again. Graphite lube works better than lithium and will not congeal with age or cold weather. You can even use Graphite lube in your door key locks to keep them loose during winter since it will never freeze up.
Americanrider is offline   Reply With Quote
Old 10-24-2005, 03:18 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Re: Jumpy Speedo
Also look for any kinks as this will cause the same problem as Americanrider described it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-24-2005, 09:54 AM   #5
cdowns
cdowns's Avatar
Re: Jumpy Speedo
i prefer a graphite based speedometer cable lube made expressly for this purpose it actually polishes the inside of the cable housing preventing future problems like the dried up caked grease will cause// available at most autoparts stores for a couple of dollars
Old 10-24-2005, 11:24 AM   #6
squeekyM
Re: Jumpy Speedo
Great advice everyone. I will give it a shot, thanks.
Old 12-19-2005, 11:03 AM   #7
Austin C10
1972 C10 Cheyenne LWB
Re: Jumpy Speedometer needle
My cable was noisy and the needle was also jumping. I cleaned it with WD-40 and then sprayed graphite in both ends of the housing. I replaced the cable, and its still jumping. Any other suggestions? Should I spray more graphite in the housing?
Austin C10 is offline   Reply With Quote
Old 12-19-2005, 11:32 AM   #8
cdowns
cdowns's Avatar
it wouln't hurt also with the cable iboth of wout check it with your fingers to see if there's a bump in it from a broken wire strand or go down the housing assy and see if there's a kink or a crushed flat spot in it both of which are difficult but not impossible to straighten out
Old 12-20-2005, 03:50 AM   #9
jimfulco
Re: Jumpy Speedo
A binding cable will make it wave back and forth in a regular fashion, with the actual speed being about in the center of the range of motion.
Sounds like you're having the same problem I have with my '79, with the speedo reading steady (or fairly steady), but 10 or 20MPH above or below the actual speed. I'm still looking for a cure, if there is one.
jimfulco is offline   Reply With Quote
