10-27-2005, 09:01 PM | #1 |
Real Men Wear Orange
Clay stuff
Has anyone else used that really fine clay to pick the mineral spots up? It's a painfully slow process on trucks, but boy does it do well. Does someone have any tips or disagreements?
10-28-2005, 03:20 AM | #2 |
Re: Clay stuff
do you mean a clay bar?
10-28-2005, 05:18 AM | #3 |
Re: Clay stuff
I have heard good things about them but don't know much else.
10-30-2005, 06:33 PM | #4 |
no brain no headache
Re: Clay stuff
claying a vehicle is like night and day. Highly recomended
1996 GMC Sierra z71 1970 SWB 2wd (project) Last edited by 70c10swb; 10-30-2005 at 06:33 PM. |
10-30-2005, 06:58 PM | #5 |
Re: Clay stuff
Is there a special brand or where do you get it and how is it done?
10-30-2005, 08:09 PM | #6 |
67-72 Addict!
Re: Clay stuff
Claying is sooooo easy!. Basically you use a detail spray for the lubricant. Do a one square foot area or so at a time. Mist on, rub the bar back and forth, wipe off with a cloth. Do the entire vehicle this way after it has been washed. Now when you wax it goes on and comes off much easier!. I've been doing it this way for 15 years. I used to do mobile detailing. I like Clay Magic brand and 3m. You can find clay kits at local parts stores and body shop supply houses. The nice thing about it is you lift the contaminants out of the paint instead of just waxing over them!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-30-2005, 10:41 PM | #7 |
Re: Clay stuff
a few other things, make sure you keep the area that you are claying well lubricated, or else it will scuff the paint. you can also just use the soap you wash your truck with as a lubricant instead of detail spray. its also a good idea to keep it in the shade so it wont dry up. when your done you'll need to wax the truck because it will take the wax off the truck as well.
