Old 10-28-2005, 08:19 AM   #1
vtblazer
vtblazer's Avatar
Looking For: Van Tilt Shift Lever
Hoping to find a van tilt shift lever in "good to better" shape.
Will take basic driver quality if that's all that pops up.
Pics of the part if you've got them would be great.
vtblazer is offline   Reply With Quote
Old 10-28-2005, 08:49 AM   #2
Tim Christian
Tim Christian's Avatar
Re: Looking For: Van Tilt Shift Lever
I have three that just came out of the chrome shop. Looks better than new!!!!! $40.00 + ride I know it soun ds a little high but I have almost 3/4 of that in the chrome work. Also they are no knob just the lever. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 10-28-2005, 06:35 PM   #3
vtblazer
vtblazer's Avatar
Can I reuse the knob on my current one?
Old 10-28-2005, 08:31 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll never get your knob off in one piece.
Does anyone know if the later keyd columns would work as a donor for the shifter? If so, I have access to a few brand new ones.
Old 10-28-2005, 09:24 PM   #5
Johns70
Johns70's Avatar
to get the old knobs off take a small propane torch and heat the handle a few inches down fron the knob and pull on the knob at the same time. don't heat to long or the knob will start to melt, don't ask me how i know.you might try on a spare or junk one first to get the timeing right for legth of time you need to heat. hope this helps. john
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 10-28-2005, 09:27 PM   #6
Tim Christian
New knob if you buy lever for $5.00 Thanks Tim
Old 10-29-2005, 12:32 AM   #7
cheyenne10
cheyenne10's Avatar
Tim;
Are those the black hard plastic knob like original or newer rubber ones?
Bob
cheyenne10 is offline   Reply With Quote
Old 10-29-2005, 07:12 AM   #8
vtblazer
vtblazer's Avatar
PM sent.
Thanks.
Old 10-29-2005, 07:17 AM   #9
Tim Christian
I have both types of knobs both are orginal just diffrent years. They run $7.00 each when sold my themselfs. Thanks Tim
Sorry no pictures.
Old 10-29-2005, 05:53 AM   #10
gregbr
Senoir Member
gregbr's Avatar
Can someone post pics, I'm trying to figure out what lever I have that needs to be replaced. Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 10-29-2005, 08:51 PM   #11
Custom 68
Custom 68's Avatar
General question I have a truck tilt and the shift lever is a bit too long for my taste is this van one shorter and a direct replacement or why are you changing this?
sorry to hijack
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-29-2005, 08:49 PM   #12
Tim Christian
Yes van tilt levers are much shorter.
Old 10-30-2005, 07:23 AM   #13
vtblazer
vtblazer's Avatar
Tim, I was waiting for someone to post up a used one in not so perfect shape but being that hasn't happened,
I'll take two please.
Another pm sent.
Old 10-30-2005, 07:18 AM   #14
vtblazer
vtblazer's Avatar
sorry to hijack
Dave
Exactly.
Old 10-30-2005, 11:11 AM   #15
Rod
Custom 68 the van levers are shorter and will fit the stock tilt. Tilts are for tilts..standard column shifters wont interchange. I see quite a few newer steering wheels which have a smaller diameter used with the van shifter. I must have ten newer steering wheels here from vans.
As for the knobs coming off..I've never had any problem here getting them off. Sometimes when I'm at a yard I just walk by and pull them off.
Rod is offline   Reply With Quote
Old 10-30-2005, 11:13 AM   #16
Longhorn Man
interesting... I've neve gotten one off...never tried too hard either.
The van column has a shorter shifter...but the early van units were big too just like the trucks.
Old 10-30-2005, 11:43 AM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
When I need a tilt lever, I make my own.
I find a nice turn signal lever (not hard, every truck has a t/s lever) and cut it shorter and cut threads onto it. It's just 1/4-20 threads cut with a die. When you're done, it looks just like a normal tilt lever.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-30-2005, 12:06 PM   #18
vtblazer
vtblazer's Avatar
Great idea but I'm looking for the auto shift lever, not the small tilt lever.
Sorry for any confusion.
Old 10-30-2005, 01:19 PM   #19
Tx Firefighter
My bad, I misread your original post. I'm glad though, I thought tilt levers were going for 40 bucks now. That did seem high for a little bitty tilt lever.
Old 12-23-2005, 01:13 PM   #20
vtblazer
vtblazer's Avatar
I forgot to post up a reply about how NICE these things are!
Shipping was very fast and the vendor was good to work with and friendly.
No hesitation about buying from Christian's truck parts again for me. Thanks Tim.
Old 12-23-2005, 02:14 PM   #21
tnblazerk5
User #12137
tnblazerk5's Avatar
yup Tims the man ! i love livein this close to him
tnblazerk5 is offline   Reply With Quote
