Old 10-29-2005, 12:11 PM   #1
84slopwaggin
84slopwaggin's Avatar
Radiator ?
In the process of replacing 305 with new stock 350 and was wondering if the stock radiator would cool it sufficiently? I was just going to have stock radiator boiled and cleaned out since it has no leaks of any kind. If it's not then what size do you guys recommend reinstalling (dimension/rows)? Truck does have A/C.
84slopwaggin is offline   Reply With Quote
Old 10-29-2005, 03:32 PM   #2
koreric75
83C10SWB
koreric75's Avatar
Re: Radiator ?
I swapped the 305 for a little more than stock 350 I kept the stock rad, runs fine never overheated or anything this whole summer in Louisiana, i drove it daily, no air conditioner in this one tho. The only problem I have had from the stock system is the heater core just went out recently.
Koreric75
2003 Suburban Z-71 4x4
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Picture&Progress Page
koreric75 is offline   Reply With Quote
Old 10-29-2005, 05:08 PM   #3
Prerunner1982
Prerunner1982's Avatar
Re: Radiator ?
the stock rad will work fine, but why not upgrade to a 4 core, you can get them at your local auto parts store for $125 give or take. Ask for a radiator for a 1ton with 454. you will need the upper mounting bracket and new isolators.. good upgrade if you ever plan on running electric fans and a good high flow water pump.. if you have a good water pump and good rad, you will hardly ever need your electric fans... unless sitting in traffic..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
