Old 10-31-2005, 07:19 PM   #1
76bonanza
76bonanza's Avatar
leaky cab
I think I got my leaky windshield under control now. But no I have small amount of water it is coming from under the firewal cardboard out undercarpet? I have heard of a seal up there somewere. Any advice and haw to get to it. Not coming form the little vent thingies.
Thanks pics would be great.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-31-2005, 08:23 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Re: leaky cab
2 more holes are the antenna grommet and the windshield wiper motor seal.
chickenwing is offline   Reply With Quote
Old 10-31-2005, 11:52 PM   #3
76bonanza
76bonanza's Avatar
Re: leaky cab
got antenna grommet it is on passenfer side this is for sure drivers side were is windhshield motor seal at?
1968 c10
lowered 3" 4"
Old 11-01-2005, 12:48 AM   #4
truckdude239
truckdude239's Avatar
Re: leaky cab
ummm i thinks its about in the middle of th dash underneith
Old 11-01-2005, 12:31 PM   #5
chickenwing
Re: leaky cab
Motor is on drivers side under dash. Round o-ring looking seal.
Old 11-01-2005, 02:56 PM   #6
tomatocity
tomatocity's Avatar
Re: leaky cab
http://67-72chevytrucks.com/vboard/s...d.php?t=178690
Does Putter's first pic offer any help identifying where the seal is?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 11-01-2005, 01:12 PM   #7
76bonanza
76bonanza's Avatar
Re: leaky cab
Just to be clear I access it from the inside of cab not from the cowl. I will check any other areas in the cowl area that access the cab on drivers side?
1968 c10
lowered 3" 4"
Old 11-01-2005, 02:27 PM   #8
chickenwing
Re: leaky cab
You remove it from inside tha cab. There is a clip under the cowl. You should be able to remove it with a pick. Installing the clip with the cowl on may prove to be a pain. I had my cowl off so it was a non-issue.
Old 11-01-2005, 02:43 PM   #9
76bonanza
76bonanza's Avatar
Re: leaky cab
Well I am thinking of pulling the cowl on weekend and siliconing anything in there that loos like it might leak to the cab ya know what I mean.
Is it just the screws on top the bolton each side to under hood and the two behind each door? Anything more to removing it?
Thanks for your help
1968 c10
lowered 3" 4"
Old 11-01-2005, 03:10 PM   #10
chickenwing
Re: leaky cab
Originally Posted by 76bonanza
...Is it just the screws on top the bolton each side to under hood and the two behind each door? Anything more to removing it?
Correct. Well, ya gotta remove the wipers of course. If you have nice paint use a friend. While you are in there use white lithium grease for any moving contact patches on the wiper assy..
Old 11-01-2005, 08:19 PM   #11
76bonanza
76bonanza's Avatar
Re: leaky cab
On removing those wiper blades is that a cover over the nut thing. Do I just pop it up with a pry bar or something?
1968 c10
lowered 3" 4"
Old 11-01-2005, 08:42 PM   #12
texascowboy593
texascowboy593's Avatar
Re: leaky cab
On your wipers at the mounting point there is a small clip. if you use a flat blade scru driver as a "pry" bar it will push it outward and the wiper assembly should come off. Do this with care as not to damage your paint!!!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 11-02-2005, 05:14 PM   #13
chickenwing
Re: leaky cab
Rokay. I kinda lost track. I was talkin lube and he was talking sealers. Guess he was suggesting the sealer instead of the rubber gasket. Would not suggest it. The gasket is rather thick and if you do not use it I could see the geometry being a little out of kilter. Maybe it would not matter... I'm definately not a rocket scientist. Did not know that about RTV. Never occured to me to use it as a body sealer though.
Old 11-02-2005, 12:41 PM   #14
chickenwing
Re: leaky cab
Originally Posted by rick980
does not silicone promote rust? just something I heard, I would use seam sealer if its not gonna be visible, nothing with silicone
*Tim Allen voice*
RRRUUUh?
Old 11-02-2005, 01:53 PM   #15
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: leaky cab
There are different silicone sealers available. If you use one for automotive purposes, be sure that it says it is safe to use. When RTV types of silicone sealers are curing, they give off an ammonia type of odor. RTV in contact with steel, will cause it to rust, eventually.
Just be sure to read the label, so you will know.
Member Nr. 2770
