How hard is it to rebuild 3 speed std trans
Looks like the trany is sticking in 2nd or 3rd, guess I need to rebuild quickly to get my son back on the road. Has anyone ever rebuilt, are the parts easy to find and is it hard to rebuild. Last night we added more fluid and its still not working right. Any help would be great.
Thanks in advance
69 LWB 70 SWB 01 Superduty Diesel 4X4 4door 06 Caddy CTS |
Questionable
Re: How hard is it to rebuild 3 speed std trans
Wish you lived nearby, I'd sell you my spare cheap. Shipping would cost too much to make it worthwhile to send.
picture: http://satellitehead.com/uploads/dri...rain%20001.jpg
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-02-2005 at 02:24 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I rebuilt one about a week ago on the tailgate of my truck (I haven't gotten my shop built yet).
A complete parts kit for the rebuild is 70 bucks if you need everything. I'd pull the side cover off first though. Second and Third gears are the front shifter lever. They have a fork inside the cover which slides a collar fore and aft, selecting between the two gears. I'd pull the cover and make sure the shift fork is engaged in the collar and moving freely. The side cover is 7 bolts. It's all self explanatory to pull it off and look inside.
senior member
TX firefighter did that rebuild include any hard parts or just seals and gears?
when my 3 speed crapped out on me i couldnt find parts anywhere same thing when my saginaw 4 speed cratered Jason
69 GMC bagged |
That's seals, gaskets, bearings, and synchros.
The gears are available too though. I use Standard Transmission (they have a good website too) for all my stuff. Not only are they nationally famous for selling transmissions, but they are local to me too.
I am a Referee of life.
If the truck has an original column shifter I would suggest checking it first.They are prone to getting dirty and gummed up.When they do they don't shift well and hang up usually in 2-3.I usually clean it by using solvent and a paintbrush or just washing it thoroughly with WD-40.Then a little lube.Also check to see if the bushings that go in the shifter arms are there and good.They make a lot of difference in the way the truck shifts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10/30/19
Not to be contrary,but my 72 will hang up going from 1st to 2nd if you don't use a little finesse when shifting.
Fight the good fight, finish the race, keep the faith |
#8 | |
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
#9 | |
10/30/19
You guys are awsome. The column shifter broke several months ago so I converted to a floor shifter, I loaned out my other column and my son really wanted a floor shifter. It worked great until this past weekend when we started with the trans problems. Last night I checked out all the linkages and they all appear to be working fine. When I shift back to neutral all the levers and linkages line up correctly. So I guess I'll be getting into the trans this weekend. Thanks for all the help.
I'd be suspicious of linkage problems, too.
If if does turn out to be an internal transmission problem, they're not too hard to rebuild, but you will either need seven hands & infinite patience, or a good lock ring plier. Here's a pic (stolen from Ebay): ![]() Vaseline will hold the little loose roller bearings in place while you put things together. Don't use the good Vaseline. A good exploded view helps, as does the ability to keep track of parts, whether you bag/label them or just lay them out in order in a place where the kids, cats, parents, etc., won't move them around for you while you're not looking. See if your parts supplier includes a diagram with the parts kit. Beware that in many cases, transmission parts that look the same are not the same, such as synchronizer assemblies (which also should remain with their original partners, hub A with sleeve A, etc.). Be sure to note which direction things point (big teeth toward the front or rear, etc.) |
![]() Join Date: Sep 2005
umm i don't know i pulled mine from my truck today due to i got an new one for 15 buxs well new to me opened mine up and man everything was messed up lol
![]() Join Date: Jul 2004
The steering column under the hood has an adjustment also that can be tightened to take up the slack between the R-1 and the 2-3 levers, it is kind of a cam type adjustment, loosen screw and turn the cam thing. If it is too loose down there, the selector can slip between and cause locked linkage and shifting problems, Also do the tear apart and grease thing on top if it move hard. It would bet you have shifter problems, not tranny problems, I would check that first.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
