KEEP ON TRUCKING
cab help
im going to swap my cab from frame to another frame friday.i have several heavy straps that they use in picking up modular houses so i know they will stand the weight of the cab.
my buddy with the wrecker says to run straps through cab and lift with the wrecker. will this bend my cab or doors or do i need to remove doors.were just picking straight up and roll frame out and other one in. any ideas on this thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
67 is sold
Re: cab help
Close the doors and put a 2x6 throuth the door frames.
Use a strap under the 2x6 and over the top, that will prevent the strap from bending up your drip rails ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: cab help
This is how I swap them. I use a strap through the window openings and chains to tag it steady...
Re: cab help
Hey Tx, What a show off.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
KEEP ON TRUCKING
Re: cab help
ok thanks alot thats what i needed to know
