Old 11-03-2005, 03:50 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
My motor RPMs don't seem right
I have a 350 with 700r4. Cruising down the highway at 60mph I'm running 3000rpm in fourth gear. At 70mph I'm about 3500 rpm. These seem high to me, I thought I had 3.73 gears but maybe I have really high ones or something?
Anyone have a calculator or experience to know if these figures are out of whack? I have 265/75/16 tires, which should lower the rpms too... I don't get it.
Jakes-66-K10 is offline   Reply With Quote
Old 11-03-2005, 04:00 PM   #2
farside847
farside847's Avatar
Re: My motor RPMs don't seem right
here is one I have used:
http://www.angelfire.com/fl/procrastination/rear.html
I also cruze at 60mph at 3000rpm with a 1:1 final gear and 3.73 ratio. I will soon be swapping to 3.08
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 11-03-2005, 06:18 PM   #3
tomatocity
tomatocity's Avatar
If your tires have a 31.65" diameter and you have a 3.73 rear gear ratio and you have a 1:1 final at the transmission: using the above calculator you would be driving 75.7306 MPH at 3,000 RPM's. To make sure check your tire diameter size. Another check is go to the drag strip and get a RPM reading as you go through the trap but be constant as you drive through the trap. This would give you an accurate speed. I doubt the calculator is incorrect but it sounds like you have a speedo gear change to make.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 11-03-2005, 04:02 PM   #4
Jakes-66-K10
Hmm, but a 700r4's fourth gear is 0.7:1 isn't it?
Old 11-03-2005, 04:02 PM   #5
70rs/ss
70rs/ss's Avatar
pull the cover off of the rear and check the ratio. It might be on the glove box, and one last question, does it go through all 4 gears? It might not be going into OD? I have an 05 Yukon XL with 3:73 and 275/55/20 and I cruise at 85-90 MPH at 2500rpm, so I am guessing you have way high gears (4:56'ish) or it is not going into OD.
70rs/ss is offline   Reply With Quote
Old 11-03-2005, 04:07 PM   #6
Jakes-66-K10
Yes, I can feel it shift to all four gear. Fourth gear at like 40-50 rpm is nice, very very quiet ride. The one thing I'm not sure it's doing is locking up the torque converter in fourth, but I have no idea how to test this (using the BowTieOverdrives kit)
Last time I looked in my diff I coulda swore I had 3.73 gears. I remember seeing a 41.11 number, which divides into 3.73. My options tag on my glovebox has been torn off and replaced by drawings of a child practicing their alphabet (previous owners.... roll eyes)
Old 11-03-2005, 04:10 PM   #7
truckster
truckster's Avatar
Here's the theoretical:
Tire size 265/75R16 should rotate roughly 650 times in 1 mile.
650 X 3.73 (diff. ratio) X .70 (final drive for 700R4) = 1683.5
At 60 MPH you should be travelling 1 mile in 1 minute, so your RPMs should be 1683.5.
Two possibilities: have you compensated your speedo gearing for oversize tires and for the drive ratios, and is your torque convertor locking?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-03-2005, 04:14 PM   #8
70rs/ss
70rs/ss's Avatar
It's the speedo! I'll bet, but wait, bigger tires should slow down the speedo?! I have 245/75/16 on the Blaze and my speedo is way slow, like it reads 50-60 when I'm doing 70?! Maybe its in the speedo gear in the tranny? I am back to betting the ratio is way high 4:11's or 4:56's.
Old 11-03-2005, 04:52 PM   #9
pjmoreland
pjmoreland's Avatar
Diff. Ratio = Engine RPM x Tire Dia. x .002975 / Speed / Transmission Ratio
Engine RPM = 3500
Tire Dia = (2 x .75 x 265 / 25.4) + 16 = 31.65"
Speed = 70 MPH
Transmission Ratio = .7
Diff. Ratio = 3500 x 31.65" x .002975 / 70MPH / .7
Diff. Ratio = 6.72
There's no way your differential ratio is that high.
I'm guessing one or a combination of things are happening.
1) Speedometer is wrong (check with a stopwatch on the road)
2) Tachometer is wrong (compare against an engine analyzer)
3) Transmission is not shifting into OD
4) Torque converter clutch is not locking
5) Differential gears are not what you think they are
Maybe the torque converter clutch is locking in third gear, making it feel like you are in overdrive.
I would definitely check your speedometer and tachometer first before disassembling anything.
pjmoreland is offline   Reply With Quote
Old 11-03-2005, 05:49 PM   #10
truckster
truckster's Avatar
It could still be the speedo gear. Depending on what the 700R4 came out of, it could be as low as 1.94:1, which would put you at about 3000 rpm at an indicated 60 mph. But I would think you would notice that everyone else was driving REALLY slow.
Old 11-03-2005, 06:04 PM   #11
Jakes-66-K10
Yeah, I don't think my speedo is that far off. In the last few weeks of driving, my indicated speed matches pretty well with what others are driving. I'll have a friend drive along side of me and check this, but I really don't think this is the problem. It could be contributing though...
How is the best way to check accuracy of a tach? When I had my emissions test done, they hooked up to one of the spark plugs and I guess it matched up pretty good.
Old 11-03-2005, 06:21 PM   #12
tomatocity
tomatocity's Avatar
Originally Posted by vortexofpain
...How is the best way to check accuracy of a tach? When I had my emissions test done, they hooked up to one of the spark plugs and I guess it matched up pretty good.
Go to a shop and have them check the tach for accuracy. Is the tach an 8 or 6 cylinder tach?
Old 11-03-2005, 05:53 PM   #13
jlmtrout
You can check you rear end ratio by jacking up the rear wheels, rotate one tire and count the number of times the pinion yoke (drive shaft) turns during one rotation of the tire. Example: if the drive shaft turns 3 1/2 times, you have a 3:43. If it turns 3 3/4 times, you have a 3:73 , if it turns 4 times, you have a 4:10. if it turns 3 times, you have a 3:08. Good luck and keep on truckin'........Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 11-03-2005, 04:15 PM   #14
67ChevyRedneck
67ChevyRedneck's Avatar
Those are some low rpm's for 60mph. My truck has a 350/700R4/3.73 and it turns about 2K @ 60mph and about 2500 rpm @ 80 mph. I can't remember my tire size, but 255/70/R15 sounds familiar, but your tires are a good bit taller than mine...... odd.....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-03-2005, 06:03 PM   #15
Blazer1970
Blazer1970's Avatar
If you are using a stock tach, there is a 99% chance that it is incorrect. They all read high with age. It is not unusual for them to be off by several hundred rpm.
Blazer1970 is offline   Reply With Quote
Old 11-03-2005, 06:29 PM   #16
tomatocity
tomatocity's Avatar
Using this calculator, http://www.angelfire.com/fl/procrastination/rear.html , and these specs:
3,000 RPM's, .70 final trans ratio, 3.73 rear gear ratio
28" tires = 95.7101 MPH
29" tires = 99.1283 MPH
30" tires = 102.546 MPH
31" tires = 105.964 MPH
32" tires = 109.383 MPH
Old 11-03-2005, 08:00 PM   #17
llegos
oh man, if you can hit these speeds a 3k, then i defintaly need an overdrive.lol
-Steve
llegos is offline   Reply With Quote
Old 11-04-2005, 01:17 PM   #18
tomatocity
tomatocity's Avatar
The more I think of it these calculations don't seem to be correct. Heck the guy is running 3.73's. I had a 95 Camaro with a 4L60E / 2.73's and I could cruise at 77 MPH and be turning 2,000 RPM's. But that was with 2.73's. I am guessing 100 MPH would have been around 2,500.
Old 11-04-2005, 03:46 PM   #19
Frank_Zeller
Frank_Zeller's Avatar
Is your converter lock up in 4th?
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 11-04-2005, 04:38 PM   #20
pjmoreland
pjmoreland's Avatar
My truck has a 700R4, 3.73 gears and 29" tires. My tach reads a little under 1900RPM when I'm going 60 MPH.
If your overdrive and torque converter clutch are working correctly and you have a vacuum switch in the torque converter clutch wiring, your transmission should feel more like a 5 speed automatic. It will shift like this: first-second-third-overdrive-tcc.
Old 11-04-2005, 05:06 PM   #21
Jim_PA
The convertor locking isn't going to drop the RPM's by a thousand, maybe 200. That's really a non-issue here. Either his speedo or tach are way off, or he has 4.56's or something. Do you have a GPS, or a friend with one that you could put it on your dash and see how fast you're really going?
Jim_PA is offline   Reply With Quote
Old 11-04-2005, 05:19 PM   #22
Frank_Zeller
In OD under load 400 to 500 rpm above lockup rpm.
Austin-Texas
Old 11-04-2005, 11:40 PM   #23
powell72
powell72's Avatar
I have the BOT kit in my truck and right after the Overdrive shift you should be able to watch the tach drop another couple hundred rpm's from the converter locking. I have 4.11's with a 275/60/15 and 70mph is 2500.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-10-2005, 02:12 PM   #24
Jakes-66-K10
*UPDATE* My truck has been in the shop for rear shock mount issues, now that I have it back I took it in today to have the tach tested for accuracy. Here is what they found:
At 1000 RPM Reading on Tach: 780 Actual
At 2000 RPM Reading on Tach: 1340 Actual
At 3000 RPM Reading on Tach: 1860 Actual
At 4700 RPM Reading on Tach: 3000 Actual
So this is a step towards solving my issue. Problem now is how to fix it... I remember seeing a hole in the back of the tachometer which seems to be where you can put a philips screwdriver in to help calibrate the tach. Has anyone ever done this though?
Since my RPMs are only 200 near idle, but nearly 1700 rpms off at high speed I'm wondering if the adjustment screw will even be able to help. What would cause a tach to be off like this? It really sucks because I bought it for a hefty price all nicely restored in a complete cluster from a board member.
Old 11-10-2005, 02:13 PM   #25
Jakes-66-K10
Oh, and I also had a tranny shop confirm that all 4 gears work great but lockup is not engaging in any gear.
