Old 11-11-2005, 11:47 PM   #1
ronh72c10
Swapping in 3/4 ton axles
I've got a 72 3/4 ton 4x4 pickup and am thinking about swapping the axles into the 71 Jimmy.
Anybody ever try this? Is it a direct bolt in or would some fabrication be required?
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 11-12-2005, 08:22 AM   #2
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Re: Swapping in 3/4 ton axles
Should bolt rite in. Your high gearing might not be as good. HO72 4.10 at best.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 11-12-2005, 08:27 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Several members here have done 3/4 ton, some even 1 ton
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-12-2005, 10:04 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Our years are a direct interchange. All of the 73+ fronts are direct as well. 73+ rears need the spring perches moved. I have a 73+ FF 14 bolt in mine.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-12-2005, 10:23 PM   #5
ronh72c10
Thanks! Now I just have to decide if I want to do it.
Ron
72 GMC 3/4ton 4x4
Old 11-12-2005, 10:29 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Ron
BIGGER IS BETTER
Old 11-13-2005, 02:25 PM   #7
ronh72c10
Yup!
72 GMC 3/4ton 4x4
Old 11-14-2005, 02:09 PM   #8
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Go for it. I did it, so it must be simple.
Baketown Scotty is offline   Reply With Quote
Old 11-14-2005, 02:31 PM   #9
garedclay
garedclay's Avatar
See http://www.4wheeloffroad.com/howto/3084/
www.clayharrison.com/truck/
'72 K5 "Georgia Red" Blazer (driver and dawg hauler)
'72 Cheyenne Super C20 LWB (parts and projects)
garedclay is offline   Reply With Quote
Old 11-14-2005, 02:39 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
IF your going to be running big tires and going off-road a lot, go for it. You may have to make a different driveline (someone correct me if I'm wrong), but everything else should be straight forward. There are a ton of guys on CK5.com running 3/4 & 1 ton gear.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-18-2005, 01:01 PM   #11
sdredneck
The Crazy Kracka
The Brake components may also need to be changed, i.e. the Master Cylinder and the proportioning valve. There is a significant weight difference and clearance difference between a 12 bolt and a 14 bolt. If you don't care about that then you will be hard pressed to destroy the 3/4 ton equipment. I would do it if it were me.
My goal in life is to be as good of a person as my dog already thinks I am.
68 GMC LWB 396 BBC Camper Special
72 Chevy Blazer 4x4 with 406 SBC
73 Dodge Dart Sport with 340
sdredneck is offline   Reply With Quote
