Old 11-13-2005, 09:43 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
Rough Country Lift Kits
Well I just read the opinions on Tuff Country kits, how about Rough Country? They are cheaper and if anything stays true in this world ..."you get what you pay for"..I even saw a complete kit on eBay today for $305.00 plus $65.00 shipping! Anyone have experience with Rough Country?? just lookin to ge the best lift I can without spending an arm and a leg.
JC
jcfoote60 is offline   Reply With Quote
Old 11-13-2005, 10:47 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Rough Country Lift Kits
Ok here's my opinion Iv'e used two rough country lifts in the past one on my 72 blazer 4",and one on my 90 burb 4",and hopefully one on my 70 burb,and yes it will probably be a rough country lift,Iv'e not experienced any other lifts so i can only tell you about rough country.these were also springs up front and blocks in rear.can't beat em for the price.I will definitely use them again.Remember just my 0.2 cents worth.Randy
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-14-2005, 06:22 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have some 4" 67-72 rough country springs sitting my garage now, I'll sell for $80 plus shipping. This is two front springs only w/ bushings. I replaced them with Tuff Country springs. The rough country springs have a high spring rate, second only to Rancho springs. The rough country spring rate is even higher than the tuff country heavy duty front springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-16-2005, 09:46 PM   #4
jcfoote60
Active Member
jcfoote60's Avatar
Thanks for the input, but I sure don't want a rough riding bouncer! Sounds like these springs are rough riding for sure. So what is the best riding lift kit out there?? I think I might re-think the go-cheap and not sacrifice my ride.
JC
Old 11-17-2005, 03:12 AM   #5
tornado_tech
tornado_tech's Avatar
Rough Country are exactly what they say "ROUGH". I got the 4" front and rear springs and there is not much flex to them at all. If you want a very good suspension kit, look at Superlift.
tornado_tech is offline   Reply With Quote
Old 11-19-2005, 02:13 AM   #6
soleeagle
soleeagle's Avatar
I have 6" Rough Country lifts on both my 85' truck and my 91' Burb. I have not had any problem with either of them. IMO I would buy another if I need one from them again. The only thing that I did notice is that the Rough Country sits about an inch higher than it is supose to be. the 6" actually sits aboout 7".
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 11-19-2005, 12:05 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Several years ago I installed a set of 2 1/2" Skyjacker Softride springs to replace my sagging fronts. I have add-a-leafs in the rear, so I didn't use the aluminum rear blocks. The springs and hardware are top quality, ride smooth, poly bushings and no squeaks or groans, and like I said I've had 'em on for several years and counting...
EDIT: fwiw, the best price I found (in 1997) was at Willard's Garage (aka Willard's Off Road Warehouse) in Billings, Montana. You can Google them for more info; they also (in 1997) had a toll free #; dunno if it's still good, but it was 800-776-8292.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-28-2005, 02:12 AM   #8
454_72_4X4
454_72_4X4's Avatar
I got Rough Country "softride" (BAHAHAHAHA!!!!) 4" lift in my big block 72.
If you're gonna buy Rough country, save yourself some more cash and just weld a 6 in piece of steel tubing to the frame and the front axle. The ride will be about the same.
I'm going Tough Country or Superlift, (if they make springs for a 72?), as soon as cash allows.
Question; Does anybody know if the 73-87 front springs are the same measurement from the front spring eye to the axle locating dowel? (Front half of the spring).
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-03-2005, 07:52 PM   #9
tornado_tech
The Rough Country does sit higher and just put on 35" boggers and still have good clearance from jumping from 33"'s. One thing noted is that when the truck was on the lift, the springs did not even move an inch so that tells you how stiff they are.
Old 12-05-2005, 11:22 PM   #10
bigarmzz
bigarmzz's Avatar
why get a rough country when you can get a superlift softride for the same price???
go to www.ntwonline.com , there where i get all my lifts, and you "usually" get a better price on the phone (for some reason)
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 12-06-2005, 12:13 AM   #11
454_72_4X4
454_72_4X4's Avatar
Wish I'd know that when I got my RC.
But then again it's been a few years since I got mine.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
