Old 11-16-2005, 03:22 AM   #1
Evs-One
Leveling my truck
IT seems that ever since I installed my Brothers' Trucks springs, my truck seems to lean to the drivers' side more. I have at most 5k miles and probably 4 years on the springs. Before, I had the front coils cut and the rears heated evenly, and the truck seemed decently level. It's really starting to bug me. I know for a fact this truck was never in a major accident...just fender benders and such(it's a 70 C-10 btw). I installed new poly cab mounts and ended up shimming the drivers side slightly to at least line up the body lines on the cab with those on the bed- the cab use to sag more on drivers side. So now, the truck is about 1/2" to 1" lower on the driver side than the passenger side, but the cab is finally even with the bed. I was thinking it's either the frame or suspension. Any ideas what to check?? Appreciate it
71 Cheyenne
95 Civic- J32A2 V6 swap
01 MDX
04 VFR800
Evs-One is offline   Reply With Quote
Old 11-16-2005, 09:34 AM   #2
BowTieMan
BowTieMan's Avatar
Re: Leveling my truck
Its a chevy truck thing. When they are lowered one side is a little lower. Even the s-10 blazers are like that.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-16-2005, 02:21 PM   #3
76bonanza
76bonanza's Avatar
Mine was like that mostly in front about 3/4 inch lower on driver. Used two of those cheap twist in coil spring spacers work like a charm level all the way around now.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-16-2005, 02:34 PM   #4
john
member #16
john's Avatar
Mine did the same thing so I put a shim on one side between the trailing arm and axle. Leveled right out. The trailing arm is inboard about half way from outside to center, so mine was 3/4 " off and a 3/8" shim corrected it. Hope this helps. john
john is offline   Reply With Quote
Old 11-16-2005, 03:49 PM   #5
MrC1
Dork For Days
MrC1's Avatar
I just installed 1.5" lowering shackles on the rear of my C20 (w/leaf springs) and the driver's side is now 1" higher than the psgr side. Go figure. I'm not planning to worry about it.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 11-16-2005, 07:40 PM   #6
Evs-One
Thanks for the help guys. I am going to slap in some lowering blocks in the rear to get me down a little further. I have a friend who works at a steel mill, so maybe I'll have him make some custom blocks that are different sizes, hoping to off set my unevenness...and for the fronts, maybe hack a section of coil out. I love the way my driver side sits, but when looking at the passenger side, it's like a different truck! Thanks for the help everyone.
71 Cheyenne
01 MDX
04 VFR800
