Por Patch
Has anyone used pro 15's Por Patch? I sandblasted the rear window opening & have some rust holes ranging from pin holes to pencil lead sized holes. I was looking on POR's web site and saw por patch, looks interesting. Thanks, Mike
![]() Join Date: Jan 2004
Re: Por Patch
I'm in the same situation. I ran across this article. you might find it helpful.
http://www.highperformancepontiac.co...306pon_shield/ Richard |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Por Patch
I have never used the por patch but if its anything like the por-15 it should work really well.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Por Patch
Thanks Richard
Re: Por Patch
I have used the stuff and was very happy with the results.
Had some pin holes in a cab floor and it fixed them very well. The stuff has the consistency of toothpaste and dries super hard. I guess I wouldn't use it on a visible panel repair because it won't sand at all but on a lip or floor it should work great for you
Re: Por Patch
i tried out a tube of it/expensive!!!/ used it to patch a crack in an abs plastic gas tank on the mower has worked fine 2years no leak// as noted a ***** to sand for a smooth finish surface//think you'd be better off with something like evercoats metal-to-metal filler if its going to need to be smooted out for final finish
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-20-2005 at 09:15 AM. |
