Old 11-21-2005, 03:18 AM   #1
blazerslave
blazerslave's Avatar
Battery & Battery Tray
After 2 years at the body shop (don't ask!) I got my truck home. The battery was shot and I went looking for a replacement. It seems that "Group 74" batteries are not really common and I believe these are the ones needed for my 72 Blazer. Has anyone has the same problem?
Also, I decided to change my rusty battery tray, but it seems that 3 of the bolts require me to remove the radiator. Is this necessary to replace the tray?
"If you choose not to decide . . . you still have made a choice."
blazerslave is offline   Reply With Quote
Old 11-21-2005, 10:54 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Battery & Battery Tray
If you can loosen up the radiator mounts on the top and slide the radiator to the side, you can get to the bolts. I just run a regular top mount battery from Autozone in all of my vehicles. There are probably better ones out there, but they warranty them and they are fairly cheap. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-21-2005, 10:02 PM   #3
69TowRig
I have a group 25 in mine, works like a champ. Ditto on the instructions above, that's how I replaced mine a couple months back.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-21-2005, 11:41 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got an optima in my blazer fits very well..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-22-2005, 03:24 AM   #5
71jimmy
71jimmy's Avatar
Yup, Optima Red Top, perfect fit!!!!!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 11-22-2005, 04:41 AM   #6
HatGuy
HatGuy's Avatar
Red top Optima here too and a new Battery Tray.
I used a universal clamp on top to hold it in place had
to modify the long threaded rods but that Battery is in
there to stay no more bouncing around. I think thats
why my Batterys never lasted more than 18 months.
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 11-23-2005, 01:22 AM   #7
Jimmy72custom
Jimmy72custom's Avatar
I will be battery shopping this week. My Napa battery cranked it's last crank. wont ever take a charge. I switch over to side terminals a while back.
Jimmy72custom is offline   Reply With Quote
Old 11-23-2005, 09:20 PM   #8
blazerslave
I found an AC Delco Group 74 battery on line, but the guy can't ship batteries. I called my local Chevy dealer and they got me the same AC Delco battery for the same price. Thanks for the advice on the battery tray. I will put it in and be ready to go!
If you're interested in a reproduction vintage battery I found those for $285.00
http://www.BatteryCentralMall.com
Here's the picture: http://www.batterycentralmall.com/Ba...pt/R89_HC.html
