Disk brake drag
The other day I had my wheel off, and spun the rotor. I know disks brakes will drag a little all the time, but this is what I considered too much. Anyone have ideas on how to fix this? I'm thinking if I can fix this, I can pickup some mileage and the truck will feel a little quicker.
~Rest In Peace~
Re: Disk brake drag
change the caliper might be stuck piston
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
![]() Join Date: Mar 2004
Re: Disk brake drag
check the sliders on the calapers first. remove them wire wheel grease and reinstall. all it cost is time wheris calipers cost $$$.
ondrew |
Re: Disk brake drag
You might want to check to see if the sliders are slightly bent. This would cause them to stick. I think you can pick new ones for fairly cheap. Good luck with your Brakes.
Bruce |
Re: Disk brake drag
Better mileage and cooler bearings.Not to mention you`ll save the rotors.Try lubing the sliders first.Then go get a caliper if they don`t free up.
Back in the sticks
Re: Disk brake drag
Second all above. You can get a brake kit for them with new bolts and bushings and that will help the calipers slide right. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
its all about the +6 inches
Re: Disk brake drag
When the wheel is off, you have so little leverage that it seems way too tight.
Jack it up and see if the wheel spins OK. |
