11-25-2005, 03:14 AM | #1 |
Ok... 700r4 Tranny Swap Questions,,, Revisited
I know we have been around this one a few times but it seems to be a good topic and gets alot of interest.
Not having done a 4speed to 700r4 swap, here is what I think I know so far. I am running the sm465 tranny and the Np 205 case. -I am told that I should look for a 1987-92 700R4 -I have purchased two kits from Advance Adapters that mate the 700R4 to my existing T-Case. 1)the Shaft Kit and 2)the actual adapter. -Two methods to make room for the extra length in the tranny are either move engine forward or move the T-Case back. *I am leaning toward moving the T-Case back but I would like to know if there is any modifications to the T-Case shift linkage in order to have it work normal in the factory location in the floor? -I am planning on installing a factory tilt column, but I have not been able to get a confirmation if in fact the factory tilts do have enough travel in the shift lever/linkage for the extra gear position? I have heard both that it is no problem and also that no it will not work. -I have also heard that you can buy a shift linkage that eliminates the factory linkage. It goes direct from the column to the shift arm on the tranny. Has anyone used this? I have heard it is very clean and makes the shift linkage much better in terms of play and so on. -I Have also heard conflicting stories on whether to look for an actual 4x4 Transmission or not. 1 story is that the 4x4 cases are a bit heavier than a 2wd tranny. Also there is something about the flywheel dust cover on a 4x4 (I think it is much heavier as well) -And at last, is there in fact an additional cross member that bolts to the tranny which is between the engine and the rear cross member under the tranny/T-case adapter. I am assuming that on an automatic truck it has 2 cross mebers under there unlike my 4speed it only has the one. Thanks in advance for any input on these questions. Curt
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
11-29-2005, 10:22 AM | #2 |
Re: Ok... 700r4 Tranny Swap Questions,,, Revisited
I took the engine trans and transfercase out of my 86 Suburban and installed it in my 3/4 ton 4x4 GMC everything was bolt in I had to drill new holes in the frame for the transfer case mount and shim it down, shorten and adapt the drive shaft, I have a tilt colum and just bolted up the linkage it works fine and I have all the gears, only real problem is the factory spedo cable is not long enough to hook to the 86 transfer case, the burban was 3:54 gears the truck is 4:10 so once I do hook it up I will probably have to change the gear in the T case. http://12.215.122.222/newtrans.htm
The TV cable was not a problem since I used the factory bracket off the burban, I still have to verify the TV adjustment and will take pressure readings before it goes back into daily driver service. |
