11-25-2005, 01:04 PM | #1 |
GMC V6 engine compression ratio
I'm a couple of years down the road from this but might as well get some feedback on it. I have a 67 GMC 4WD with a 305E V6, manual trans. Specs say it has 7.75:1 compression.
Question: How much compression can you add to this engine before you run into overheating, head gasket sealing, valve clash and other problems? I'm thinking of taking it up to 8 or 8.5:1 when I do the engine. But I would like to know how high you can go before these issues begin to surface. I'm looking increase the torque. Maybe a low and flat torque curve. No revs over about 4,500. Maybe going to the Holley 2bbl on the stock manifold, headers, duel exhaust and all that stuff. Its got 3.73 gears in it now but I think I want to go back to the original 3.54 or there about ratio. And I running 31x10.50 tires.
67 GMC 4x4, 305 V-6, 4-spd 86 S-10, 2.8 2WD LWB 01 Suburban (family hauler) 13 Honda CRV (wife's wheels) 03 Malibu (daughter’s car) |
11-25-2005, 02:31 PM | #2 |
its all about the +6 inches
Re: GMC V6 engine compression ratio
I would imagine 3.07 would be even better in all honesty.
Being it has iron heads, and old school chaimbers, I wouldn't go over 9 to 1... if you get a custom cam with a little more overlap that stock, one that'll bleed off some pressure, you may be able to get away with 9.5 or so, but I don't know how you would even get those numbers. That is way too much to mill the heads. |
11-25-2005, 09:31 PM | #3 |
Cantankerous Geezer
Getting the revs over 3,500 is going to take some major work on the crank, which has some big weights. One of the problems with the GMC V6 was with balance and it's inability to handle high revs. The engine doesn't like a diet of sustained rpm of over 2,500 rpm, and will spit out the rods like there's no tomorrow. Been there, done that when the engine was in production.
If you haven't already been there, go to www.6066gmcguy.org
Fred There is no such thing as too much cam...just not enough engine. |
11-26-2005, 05:08 AM | #4 |
Where's my beer?
..............................and the big dogs have spoken.....................
Paul How do you make the invisible, visible?.........You take it away. |
11-26-2005, 07:43 AM | #5 |
I haven't got a tach on it yet and haven't done the math on everything but it feels like it doesn't want alot of RPM. In high gear the motor feels and sounds like it doesn't want to rev any higher at around 50 mph. Which is fine with me, I'm just exploring ways to improve on the torque in and around the current RPM range.
I'm afraid that if I got too low on the rear ratio I'll loose the power that it has now. When it all done I'm only going to use the truck in the winter to get around.
07-15-2006, 03:59 PM | #6 | |
The only bad thing for a V-6 is RPM's...........
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
07-15-2006, 06:12 PM | #7 |
As far as increasing the compression ratio on the GMC V-6, you are really limited. About all you can do is mill the head. Stock pistons are hard enough to find, and to my knowedge high compression pistons were only availble for a short time in the 60's, when they were made for industrial V-6's running on propane or natural gas. Good luck finding a set of those! No doubt the 'Magnum' heads and manifolds are better than the stock 305's, and the 500 cfm Holley is a big improvement, too. But I wouldn't try making a hot rod out of a GMC V-6. It just wasn't designed for it.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
07-15-2006, 09:33 PM | #8 | |
Aluminum slot wheels rule...
11-29-2005, 02:38 AM | #9 |
You are the only person I have ever heard of that wants to get more bottom
end grunt out of a GMC V-6. These engines are ALL GRUNT!! As others have said, they don't like to spin, but you can lug them all day.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
11-29-2005, 11:15 AM | #10 | |
11-29-2005, 10:53 AM | #11 |
I am rebuilding my 305 V6 and doing several performance improvements. First I bored it .030 over. I had a the cam reground for more performance, since you can not buy a new one. I have GMC 351 V6 magnum heads, intake and exhaust which have much better flow than stock. The heads were ported and polished, by me. The heads have been milled .070 to give 8.8:1 compression ratio. I am using a Holley 500 CFM carb and a custom Buick V6 HEI. I hope to pick-up about 40 horsepower. When it is finished I will take it to a local dyno, then post the results. I am sure someone will tell me to buy a Chevy 350 to get better performance and save money. I want the look of the original engine with some more power.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
11-29-2005, 02:40 PM | #12 |
Thanks Erl, I will be very interested in what your results will be. I guess I'm just a rookie with this engine. I'm fast learning that you can lug this engine more than the norm. I'm also finding out that my old truck is kinda rare so I think changing the engine would be a disgrace to its history. Keep the progress posted.
07-14-2006, 08:50 PM | #13 |
Hey Erl, how'd your V6 turn out after you got it all done??
07-14-2006, 10:11 PM | #14 |
Page intentionally left blank.
I'm interested that this surfaced as well, I had not come across this thread in my back reading on the board. I'd very much like to know what all has been/can be done to these engines, beyond the tips on Jolly's site. Any rebuild tips and tricks could help as well. I'm already planning on the Magnum heads/HEI mod, but wondered about balancing and porting/polishing. Any real world input would be appreciated!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
07-15-2006, 09:04 AM | #15 |
The Holley 500 2bbl. carb seems to work wonders on them, and my truck doesn't run quite 100%. They're still slow, but have better pick-up than with the stromjunk. Another thing you could do is get a set of heavy-duty truck exhaust manifolds, with the 3in. outlets. (like cast iron headers IMO) I've heard that back in the 60's, Hot Rod Mag had a 305 V6 on the cover with a Offanhauser 3x2 intake, and Hooker headers. But thats just a rumor.
07-15-2006, 10:13 AM | #16 |
compression ratio has nothing to do with valve slap. compression ratio is simply the compression of one, or all of the combusion cylinders. im runing 9:5:1 with 87 octain.
07-17-2006, 02:04 PM | #17 |
I am still working on the rebuild. I have switched gears since that last post. I have a set of 351 magnium heads, intake and exhaust manifolds ready to go on it. This did cause a problem. The combustion chamber volume of the 305 heads is 100cc and the volume of the 351 heads is 120cc. This will bring the compression ratio down to 6.8:1. To make this work I had to purchase custom pistons from Arias Piston Co. That set me back $700. They could not guarantee any more than 8:1, because of the size of the thier stock piston forging. The big V6 has a large compression height and wrist pin dia, which limited the dome volume. I will know in a couple of weeks when they come in. If you think this is a waste of money, keep it to yourself, this is a hobby not a business. Desk Top Dyno predicts about 275 HP and about 325lb-ft of torque. I will take some pictures and post them later.
07-17-2006, 06:36 PM | #18 | |
07-23-2006, 09:01 PM | #19 |
Howdy,
I'm new to the board but have been running these trucks for over thirty years. Check the exhaust valves, some of these motors have sodium filled valves with hardened valve seats, you want those for unleaded fuel. The top end oiling is fed from the rear main camshaft bearing, it has a partial groove around its circumference, have the groove machined all the way around. Have close tolerance valve guides installed, if nothing else do this, the valve guides wear and the performance drops. If you can get them use the pistons with four rings and follow the factory original spacing and clearances. Install a five pass radiator, you'll think your temp gauge is broken, don't care how hot it is or what you do, it won't overheat. Best regards, Butch ---- 65 3/4T 4x4, fuel injected 305E V6, SM 420, Gear Vendors, NP 205, BFG 35's on Weld SS, and some other stuff. |
