Old 11-28-2005, 10:54 AM   #1
MEANGREEN70
MEANGREEN70's Avatar
Question crossmenber help
Like many of you guys iam trying to get as much info as i can on a crossmenber drop. IAM working on a 70 chevy short bed stepside, I have the rear done is all bag and working fine. the front i have bag also and drop spindles, the problem i have is that the back is lower than the front when is air out. The rear with sit on groung the front wont, I found a link in here I think it was from a site call www.jayspot.com . my ? is, has anybody done i crossmenber like this or what do you guys think about it or what would be the best way to do a crossmenber.I dont know if the guy in jayspot had any problems with the steering. As soon as i can figure out how to post pics i will.
MEANGREEN70 is offline   Reply With Quote
Old 11-28-2005, 12:58 PM   #2
DM310
Re: crossmenber help
to me it looks like he just raised the mounting point of the air bags. The crossmember itself stayed in the same location. If your lca's are keeping you from going any lower then that mod wont help you
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 11-28-2005, 01:58 PM   #3
SCOTI
SCOTI's Avatar
Read through the crossmember drop thread in this section. It has lots of good info & should answer many questions you might have.
http://67-72chevytrucks.com/vboard/s...ad.php?t=60649
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2005, 03:25 PM   #4
MEANGREEN70
is tunner still in businnes?
Old 11-28-2005, 05:52 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
No, turner is not still in business. I build these crossmembers as mentioned in the thread Scoti posted. Here is a thread on the install of one I modded for a member. http://67-72chevytrucks.com/vboard/s...d.php?t=137398
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-29-2005, 05:58 PM   #6
MEANGREEN70
CAPTKAOS, are lots of problems with the steering using the crossmember that u make and how much are they?
Old 11-29-2005, 06:30 PM   #7
Captkaos
Captkaos's Avatar
$385 + $75 (unless you supply the core) + shipping (typically has been $30-$50).
The steering issues are going to be the same as any drop method. You will have to u-joint the steering rod around the upper control arm as noted in the link above.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
