11-29-2005, 10:56 PM | #1 |
Radiators
ok so i will be ordering my 4 core rad soon, but when i called Chevy Duty today, they said that people have had problems with GMC's. since then i have found that radiatorexpress.com has them for cheaper, with a reputable brand(modine). I have a 3 core, and will be replacing it with a 4. this will fit right? I do plan on getting the 4 core brackets/pads from earlyclassic.i am just making sure this will all work right together.....comments?
thanks steve
-Steve |
11-29-2005, 11:17 PM | #2 |
its all about the +6 inches
Re: Radiators
I'd hate to say a top notch company like chevy duty doesn't know what they are talking about...but a GM truck is a GM truck, be it chevy or GMC. They both came stock with them, and the engines are mounted in the same location...
11-29-2005, 11:23 PM | #3 |
Re: Radiators
ok thanks. they said that some customers who happened to have GMC's experienced the issue, so i think it might have been more of a 'look out' so they wouldnt have to deal with that.
-Steve |
11-29-2005, 11:35 PM | #4 |
R.I.P. E.S.L.L.
Re: Radiators
I got a new 4 core for $158.00 delivered and they delivered it in an hour (I couldn't believe it) If your interested let me know and I'll find the name and # of the company. I don't have it handy, it's in the garage somewhere.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
11-29-2005, 11:55 PM | #5 |
Re: Radiators
well, everything helps....if you dont mind going out and checking it, that would be awesome
-Steve |
11-30-2005, 12:21 AM | #6 |
R.I.P. E.S.L.L.
Re: Radiators
I found it on Ebay just type in Chevy Truck Radiator , they are called the radiator doctor $133 + $15 shipping and like I said it was here in one hour. Now I'm no expert on radiators but the a 4 core with less of a guarantee was $400++ plus shipping in the 67-72 truck catalogs.. Forget the Buy It Now just call the 800 number. I'm happy.
11-30-2005, 12:54 PM | #7 |
Re: Radiators
i just got mine from radiator doctor in a day and it was great dave
01-16-2006, 12:49 PM | #8 |
Re: Radiators
Well y'all convinced me to order mine there too. I just paid, I'll let y'all know what I think of it when it gets here.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
01-22-2006, 02:58 PM | #9 |
Re: Radiators
Well the radiator is nice but I was NOT impressed with the packaging. My brand-new radiator arrived with a couple dings in it already. The cardboard box they ship in is flimsy to say the least and the foam is VERY sparingly used in the box.
I wish I knew that they ship locally, not 8 miles from here. I would have picked it up...
01-22-2006, 03:37 PM | #10 |
Re: Radiators
I had to modify my shroud when I went from a 2 core to a 4 core. I will eventually replace the shroud, but I thought I'd give you a heads up.
Good Luck, - Jim
72 Chevy C-10 Custom LWB 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! |
01-23-2006, 02:03 AM | #11 |
Re: Radiators
LMN8UR, I think he probrably hit that step already since I dug this old post up from November. I, however, did not discover that the radiator was that much differentuntil this afternoon when I was trying to ditch the 2-row for the 4-row I purchased. Oh well, LMC now has even more of my money. For now the radiator is ZIP-TIED in and works great. My old 2-row was plugged so bad that the truck threatened to overheat if driven for more than 10 miles at highway speeds. Now it is a cool cucumber!
What did you have to do to the shroud? I left mine off for the time being... Last edited by 69TowRig; 01-23-2006 at 02:05 AM. |
01-23-2006, 02:01 PM | #12 |
R.I.P. E.S.L.L.
Re: Radiators
I'm suprised that yours was not packed well, mine was really well packed.
maybe they use different vendors in different parts of the country.
01-23-2006, 02:06 PM | #13 |
Re: Radiators
I bought the 4-row one from radiator doctor too.
I bought new mounts from one of the suppliers on this board. The radiator did NOT fit as I expected. However it turns out the problem is the aftermarket pads I bought new for the new mounts. They are taller than the stock ones. I ended up making little spacers for the top of the fan shroud to hold it to the top. At the bottom I have zip ties holding it in place. It has worked good for over a year that way.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-23-2006, 03:37 PM | #14 |
Re: Radiators
I had one zip tied for a while, you need to put something in between the tank lips and the core support to keep the metal to metal friction down. FYI...the core support will win the battle.
01-24-2006, 01:09 AM | #15 | |
Re: Radiators
01-23-2006, 04:23 PM | #16 |
Re: Radiators
The radiator sits and fits fine. However the aftermarket pads move the radiator UP just a touch. The zip ties I'm using are holding the shroud in place at the bottom (in place of the clips the shroud used to slide in to.)
At the top I had to make little metal spacers. They are only about 1 inch tall. The original sheet metal screws screw into the spacer at the top of the spacer. The bottom of the fabbed spacers is then holding on to the shroud with 1/4-20 nuts and bolts. I have a picture on my PC at home. Yes. You do NOT want a radiator rubbing on the core support.
01-23-2006, 10:20 PM | #17 |
Re: Radiators
Here is a picture of what I had to do using all aftermarket pads and mounts.
Somebody on this board told me the aftermarket pads are too thick.
